frank60
Maine
I have a 1994 Coachhouse Class'b' and I have a leak in either the Black and/or Gray water valves, I believe they are the originals.
The current bayonnet drain cab extends about 1" beyond & underneath the running board on the drivers side. My concern is the Valterra Twist On would extend another 4 1/2" to 5" beyond the current cap, not to mention that the whole valve system would be exposed.
Has anyone done what I'm thinking of doing? or Does anyone see a problem or have any suggestions with what I want to do?
Thanks in Advance
Frank
GMC_jon
Arizona/Virginia
What is it you want to do?
Just asking.
John
frank60
Maine
John,
I'm sorry, I guess i wasn't clear enough. I want to put on the Valterra Twist-On Valve in place of the current bayonnet cap but concerned about it extending furthe out from the side..
Frank
CA Traveler
The Western States
frank60 wrote: John,
Frank In that case why don't you replace the valves?
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
hallock5
I use Twist on solution for black water leak by issue, best $25 quick solution I can find, but it is parallel with the side, so no "stick out" issue.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
GMC_jon
Arizona/Virginia
Frank,
If changing the valve(s) is a no go, then you might consider either a 45 or 90 degree elbow at the bayonet before the Valterra and the cap after the Valterra.
The cap facing straight down would be my choice as a container could be placed under it, to collect seepage, when you are ready to attach the hose.
Just a thought
John
tvman44
Southwest Louisiana
I'd change the valves, not that hard to do.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
