RV.Net Open Roads Forum: Frequently Asked Questions (FAQ) on the Open Roads Forum
 > Frequently Asked Questions (FAQ) on the Open Roads Forum
LLeopold
Camarillo, CA USA
Posted: 06/17/02 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Frequently Asked Questions on the Open Roads Forum
Click on any of the underlined bulleted subjects below to open the subject thread.
If you don't see any clickable links in a topic, try using the search utility (the magnifying glass in the upper right corner) See "About this thread" after the list. If you find it useful and think it will help others, please share it here as well.
Before you begin:
It is good to review the Forum Rules from time to time just to confirm what you agreed to when becoming a member of the Open Roads Forum and by popular demand: Acronyms and Abbreviations Used in the Forum
Another question that comes up frequently is how a member goes from "New" to "Full" to "Senior" status. It is purely based on the number of posts made and not how much the member knows (though some will have you believe the latter!). "New" members have made 0-49 posts, "Full" members 50-249 posts, and "Senior" 250 and more posts. Also, when one becomes a Senior member, it is customary to send each of the members who are "Moderator" $20.00... (I'm kidding!) .
And finally, a note for Good Sam Members: If you are an active Good Sam Member and you have registered on the forums using the same email address that is associated with your Good Sam account, your profile will, by default, display a small Good Sam Logo Badge when you post indicating you are a Good Sam Member. If you do not want the badge to display, log out, clear your internet cookies, and log back into the forums, go to My Forums/My Profile and select NO in the drop-down menu beside the words "Show GSC badge". Then go to the bottom of the page and click on "Submit Changes".
0. How Do I Get My RV.NET Stickers?
1. How to Decide on the Type of RV and Things to Consider
2. Checklists & Procedures
3. Weighing your RV & Weigh Stations
4. Hitches
4a. Fifth Wheel Hitches and Sliders
4b. Weight Distribution Hitches
5. Brake controllers
6. Tire Pressure
7. Dually Inflation
8. Valve Extenders
9. Tire Pressure Monitors
10. Air Compressors (often discussed under tire pressure)
11. Wal*Mart and Other Free Camping
12. Black Streaks and How to Remove Them
There is a Part II to the FAQ - please see the next posting. -LL
* This post was last edited 11/30/09 10:05am by LLeopold *   View edit history
LLeopold
Camarillo, CA USA
Posted: 06/17/02 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Frequently Asked Questions (Part II)
13. Should I camp at Fort Wilderness and Other Disney Camping?
14. Camping Costs and Memberships
15. Engine Oil
16. Roadside Assistance Plans
17. Electrical, Batteries, Solar, and Generators
18. Mileage
19. Traveling with Propane On
20. Plumbing, Fresh Water, Holding Tanks, Toilet Paper and Dumping
21. Working with the Forum
There is a Part III to the FAQ - please see the next posting. -LL
* This post was last edited 06/13/10 07:57am by LLeopold *   View edit history
LLeopold
Camarillo, CA USA
Posted: 06/18/02 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Frequently Asked Questions (Part III)
22. Sway Control
23. Preparing for Winter and Spring
23a. Winterizing
23b. De-winterizing
24. Truck Camper FAQ’s
25. Spray-in Truck Bed Lining
26. Other Good Things to Know About
27. Outside Reading/Links/Fun Stuff
(Note: This list contains links to pages on the World-Wide Web that contain even more useful information for the new and experienced RVer)
About this thread:
This thread is a kind of an "Index" to topics that have been raised many times on the forum. It is not a "Topic Search Engine." That is already provided by the forum (the magnifying glass in the upper-right corner).
It is by no means all inclusive of all the discussions done on this forum. To maintain a true index is a daunting, if not impossible, task.
It is also definitely not meant to stifle discussion nor to quash any new topics from being created. It is here to provide quick links to some discussions that have taken place in the past. Any new information is always welcome to any of the threads or even new ones. If you are aware of a topic and thread (or created a new topic and thread) and want it added here, please post a reply to this thread with the FAQ (even if its a new one) and the link to the thread so I can copy it here. This is also true of threads I may have missed (especially in the early stages!).
Please note: As an RV enthusiest, I go camping as often as I can, so if you post a reply and I don't immediately respond, please don't be upset with me. I'll do my best to see that the thread gets added as soon as I can.
Where and how this all got started.
How to get a link added to this FAQ
If you come across a thread that should be added to the FAQ, or even a whole new FAQ category that would be helpful to others, please reply to this thread with the information.
Start by going to the desired thread with your browser.
Then capture the URL of that thread so that it may be copied into your reply. For Netscape, the URL may be found at in the "Location" window. For Internet Explorer, the URL may be found at the "Address" window. Both are found immediately above the main browser window.
Select the URL using your mouse (position your mouse at the start of the URL and slide the mouse to the right until the entire URL is highlighted) and press the Ctrl and C keys together (Ctrl-C) to select and copy the text of the URL.
Then come to this thread and post a reply. Paste the URL into the Reply body by positioning the mouse in the Reply window and pressing the Ctrl and V keys together (Ctrl-V). The URL should now be entered as text to the reply. Insert the title of the thread to the reply (just makes my job easier) and submit. That's it.
Note that when the link has been added to the FAQ, the reply containing the initial link posting and my confirmation reply will be deleted by the Admin so that the FAQ thread itself will be manageable.
If you find that a link is not good
Please reply to this thread with the line item that is the bad link and I'll remove it from the list. I do not check each and every link regularly so I may (read will) miss links that no longer work. I appreciate it when these are pointed out.
* This post was last edited 09/24/09 04:56pm by LLeopold *   View edit history
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
