RV.Net Open Roads Forum: Class A Motorhomes: Wood Pads under MH Tires ?
 > Wood Pads under MH Tires ?
deejay41
Alabama
Posted: 04/05/13 08:24pm Link  |  Print  |  Notify Moderator
Does anyone park their MH on wooden blocks?
I was told that it would help protect the tires from the bad effects of moisture.
I have a concrete RV pad, and I have been using the wooden pads under my tires.
Today, I noticed that the driveway concrete was completely dry, but the wood pads under the tires was still waterlogged.
It seems to me that it is more harmful to park on the wet wood, than to just park on the dry concrete.
Any thoughts??
US Air Force (retired)
Tiffin Allegro Bus Class A
Cat Diesel Pusher
Blue Ox Aventa 2 w/ Brake Buddy
Dodge Dakota - Toad
Have Dogs-Will Travel
tahiti16
Camarillo, CA
Posted: 04/05/13 08:29pm Link  |  Print  |  Notify Moderator
Many use something like the acrylic cutting boards under the tires, idea is to isolate the tire from the leaching effect of the concrete. Wood on the other hand can have the exact issue you have found, it can hold water.
Ray, Cheryl & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
haddy1
Chesterfield, MO
Posted: 04/05/13 08:37pm Link  |  Print  |  Notify Moderator
I have always parked mine on plywood pads, but that's in my garage. Marine plywood would probably be ok outside.
2012 Tiffin Phaeton 36QSH
2007 Jeep Wrangler Toad
robsouth
Metro-Atlanta, GA
Posted: 04/05/13 08:59pm Link  |  Print  |  Notify Moderator
Some use roofing shingles. Don't really know why.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
enblethen
Moses Lake, WA
Posted: 04/05/13 09:02pm Link  |  Print  |  Notify Moderator
Water is trapped between the wood and will also be trapped behind cutting type nylon boards.
Yes, plywood will abosrb it and eventually rot out.
Rubber door mats like from Lowes would still trap the water but won't rot. Less expensive then large cutting boards.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CloudDriver
New Jersey Shore
Posted: 04/05/13 09:06pm Link  |  Print  |  Notify Moderator
I park our Class C on sections of 2X10 boards. Our driveway has a shallow slope, so the front tires are on ramps three boards high and the rear duals are on single boards. For a time I had used plywood under one set of duals, but the plywood warped, collected water and stayed wet. The 2X10 boards dry quickly. Up to last year the driveway was gravel, as seen in the picture. We had it paved with asphalt last year and the boards now have the additional purpose of keeping the tires from sinking into the asphalt.
2003 Winnebago Minnie 24F - Ford E-450">
happy-2
calif
Posted: 04/05/13 09:50pm Link  |  Print  |  Notify Moderator
I have been using rubber belting for years,it keeps the tires off my concrete pad and never any moisture problems. u can also use rubber pads from harbor freight.Will last a lot longer then wood,
ronfisherman
SE Michigan
Posted: 04/06/13 04:07am Link  |  Print  |  Notify Moderator
I use a cut up horse mat from Tractor Supply Company. One mat will do 2 MH's.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Posted: 04/06/13 04:09am Link  |  Print  |  Notify Moderator
Park mine on concrete for years NC's years. Makes no difference. Never had a problem.
sailor_lou
Connecticut
Posted: 04/06/13 06:55am Link  |  Print  |  Notify Moderator
Directly from the Michelin web page:
LONG TERM STORAGE OF RV TIRES
Unless the RV owner is a full-time RV-er, the vehicle
probably spends some time in long-term storage. But
what the RV owner probably didn’t know is that rubber
tires age when not being used. So, if the owner must store
the RV, a cool, dry, sealed garage is the best bet. Also, some
storage surfaces can cause tires to age faster. That’s why
Michelin recommends placing a barrier (cardboard,
plastic or plywood) between the tire and the storage
surface.
For additional info go here and click RV Tire Guide:
http://www.michelinrvtires.com/michelinrv/toolbox/reference-material.jsp
Lou
05 Travel Supreme Envoy
