RV.Net Open Roads Forum: Tech Issues: Oil recommendations cold weather generator
 > Oil recommendations cold weather generator
pianotuna
Regina, SK, Canada
Posted: 10/04/13 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Hi Paul,
I would be interested in a "remote stop". But if the price were right--yes it makes sense.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
Gulfcoast
Southeast
Posted: 10/04/13 09:21am Link  |  Quote  |  Print  |  Notify Moderator
At those temps... I'd only shut it down to refuel and change oil. smile
mlts22
Austin, Texas
Posted: 10/04/13 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I'd consider a remote start kit as well. Just so that you don't have to go out in the weather to turn the key or yank the pull handle.
Of course, one nice thing about the Yamaha generator, if it won't start due to the battery being low from the electric ignition, there is always the pull rope.
time2roll
Posted: 10/04/13 09:58am Link  |  Quote  |  Print  |  Notify Moderator
If the manual calls for 10w30 that is exactly what I would run.
675w Solar pictures back up
Sundance07
Medicine Hat, Alberta
Posted: 10/04/13 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Have you ever experienced -30 or colder temps?
If you've ever had to start equipment in those temps you would realize a 0w-30 vs a 10w-30 can mean the difference in getting it started vs just having a cold lump of steel to look at.
FWIW The coldest I have started our gensets have been -62c. Not gonna happen with 10w-30 without a heat source.
2012 Ram 3500 4x4 CCLB/DRW Laramie, Cummins 6.7 HO, 68RFE, 4.10 Max Tow, Firestone Ride-Rite, 50 Gal Transfer Flow
2008 Citation Supreme Platinum XL 34.5 CKTS, GVW 15500, MorRyde, 4 wh disc brakes, -30C Polar Pkg
time2roll
Posted: 10/04/13 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
No. IIRC never been below -10F. Truck started just fine. My old car used to have trouble with the carb icing up so it would not idle for 5 or 10 minutes. Still started.
IMO getting started has more to do with fuel, compression and ignition. Oil may come into play if the electric start system becomes marginal at those temps. Pull start should still work. Diesel is another set of trouble but does not apply here. But I have never owned a diesel either [emoticon]
At -30 overnight my generator would have been running all night and most of the day. It would never really get cold. Pianotuna knows his limits.
My concern would be less protection when warmed up and running for extended periods.
-62c? was that Monday, February 3, 1947 Snag, Yukon? [emoticon]
http://en.wikipedia.org/wiki/List_of_extreme_temperatures_in_Canada
* This post was edited 10/04/13 09:56pm by an administrator/moderator *
nevadanick
Elko, Nevada
Posted: 10/04/13 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
In -40f my old Ford wouldnt turn over fast enough to start no matter how many batteries and how good they were. Cold temps make its own rules.
dddire
Canada
Posted: 10/05/13 01:31am Link  |  Quote  |  Print  |  Notify Moderator
I would always use a full synthetic no matter what temps... but 0w30 Amsoil would be my choice here.
* This post was edited 10/05/13 06:20am by dddire *
Learjet
Louisiana
Posted: 10/05/13 07:13am Link  |  Quote  |  Print  |  Notify Moderator
My Yamaha EF2600 has a chart, and calls for straight 10w below 32f.
Might want to look in your manual again.
2017 Ram Big Horn, DRW long box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Sundance07
Posted: 10/05/13 08:41am Link  |  Quote  |  Print  |  Notify Moderator
No sir, It was Mile 115 of the Alaska Hwy then another 120 miles north of that. About 1998 or 99. Brrrrrr...........[emoticon]
Nice link.....thx [emoticon]
