RV.Net Open Roads Forum: Southwind Fuel Pump - Where is it?
 > Southwind Fuel Pump - Where is it?
snifterpie
San Diego, CA
Posted: 08/11/03 03:04pm Link  |  Print  |  Notify Moderator
I have a 30' 1991 Fleetwood Southwind with a Chevy 454 engine and cannot find the fuel pump. Can anyone help me out please?
96Bounder30E
America is my home!
Posted: 08/11/03 03:11pm Link  |  Print  |  Notify Moderator
Have you tried looking in the gas tank?? If not that is where you will find it....
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
cdking1
el paso, texas usa
Posted: 08/11/03 03:13pm Link  |  Print  |  Notify Moderator
Hi, I think it may be in the gas tank. If it is the guage and sending unit are with it. I don't remember what year they started putting them in the tank but it could not hurt to check it out. charlie in texas
1999 Southwind ford V10
Gibson hedders and exhaust
Tacoma, 4x4 toad
snifterpie
San Diego, CA
Posted: 08/11/03 03:46pm Link  |  Print  |  Notify Moderator
This may sound real stupid, but how do I look in the gas tank?
chairboy
Culver City, CA, USA
Posted: 08/11/03 03:53pm Link  |  Print  |  Notify Moderator
I don't know the answer, but I suggest you avoid using a lighter or candle.
1984 Fleetwood Southwind 33'
1 Kid, 1 Wife
hallert.net
chalmation
chalmette la
Posted: 08/11/03 04:09pm Link  |  Print  |  Notify Moderator
hi i have a 92 chevy 454 the fuel pump is in the tank hope it's not full. i had about 20 gals when i had to drop my tank still heavy let me know if you have to drop yours i know a easy way.
MaineRoger
Livermore, Maine, USA
Posted: 08/11/03 04:54pm Link  |  Print  |  Notify Moderator
If you put your ear in the area of the gas tank and have someone turn the ignition switch from off to on (do not start), you should be able to hear the pump run for 2 to 5 seconds and then shut off. Your question seems to indicate that maybe you are trying to solve a problem vs just being curious. If you are trying to solve a problem just let us know what it is and someone should be able to help you.
Roger
Remember: Rear Drum Brake users; please do not forget to use the brakes when backing up occasionally to adjust them.
1989 Winnebago Chieftain
Chevy 454, Bilstiens
148,100 miles/115,000 of them mine.
No pets, no co-pilot.
Big Suitcase: Winnie
Little Suitcase: 1400 miles on AT in 2001.
325 miles in 2003.
Ken Saville
Palmyra,NJ
Posted: 08/11/03 10:13pm Link  |  Print  |  Notify Moderator
If it is like my 1990 454 there are two fuel pumps. One in the tank and a second one on the right (passengers ) side of the front of the engine. I had to replace the one on the engine about 5 years ago but the one in the tank (knock on wood) works fine.
You also have a fuel filter on the frame rail on the passenger side probably just forward of the entrance door. If you have a carb. you also have a filter in the inlet of the carb.
Have you run a fuel pressure check?
snifterpie
San Diego, CA
Posted: 08/12/03 12:29am Link  |  Print  |  Notify Moderator
The fuel pump has been found...in the fuel tank. It is working fine, but the power to it has been knocked out from the fuse box. Just need to re-wire. Thank god I dont have to replace it. The tank holds 65 gallons of fuel and is full.
Thank you all.
9lives
Anchorage, Alaska
Posted: 08/12/03 01:02am Link  |  Print  |  Notify Moderator
Glad that you found the problem. Hope you have it running soon....
good luck
Bill & Susie
Annie the Pommie & Randy our cat
1999 Hurricane 34' w/slide, v-10
1998 Jeep Wrangler Sport
