RV.Net Open Roads Forum: Towing: F250 Towing Capacity
RV.net
Search only in Towing
Open Roads Forum  >  Towing
 > F250 Towing Capacity
62cwil
Carlsbad, CA
Posted: 02/14/03 07:35am Link  |  Print  |  Notify Moderator
SuperCab with 4 sp A/T and 8800 GVWR package and 3.73 Ration Limited Slip Axle. According to Trailer Life the towing weight is 13,700 pounds. I tow 5th Wheel. You talk 5 folks and get 5 variations of answer. Does anybody know exactly what that means. In other words does it mean the trailer you tow can be up to 13,700 loaded or what? Any help appreciated.
penguin149
Monroeville, AL USA
Posted: 02/14/03 08:27am Link  |  Print  |  Notify Moderator
It depends on what motor you have. V10 & deisel with that rear end has a capacity of around 10,000#. 13,700# sound like a 4:30 rear end. The 5.4L V8 has a capacity of around 8,900#. With a fifth wheel, you'll need to watch the pin weight and not exceed to rear axle rating.
Jim
2007 F150 5.4L Supercrew, 3:73LS & 2002 Keystone Bobcat 293EBS
Qc Traveler
Chateauguay, Quebec. Canada
Posted: 02/14/03 12:24pm Link  |  Print  |  Notify Moderator
Here is a link to Ford's 2003 towing guide. It explains everything you need to know.
http://www.fleet.ford.com/products/rv_trailer_towing/2003/2003_default.asp
Fred & Brenda
2003.25 F350 6.0L 2x4 PSD CC SB Lariat
Linex bedliner
Lund Grill inserts
Prodigy controller
Husky 16K E-Z Roller
2009 Crossroads Cruiser CF30SK Triple Slide
Comdac
Virginia Beach, VA
Posted: 02/14/03 02:07pm Link  |  Print  |  Notify Moderator
Hi Charles,
Yes, it is confusing. I, too, have a vehicle identical to yours. The GCWR is 20,000 lbs and my truck weighs 7000 lbs with a half tank of gas. This leaves only 13,000 lbs of towing capacity. When my wife and I get in and I put my generator and a load of firewood in the bed, the available towing capacity decreases even more.
I have only 1800 lbs of carrying capacity before the GVWR is 8800 lbs is exceeded, so that leaves very little left over for hitch weight when my wife and I get in and I put my generator and a load of firewood in the bed.
Since the RV that I want to tow can weight up to 14,000 lbs, I bought this:
http://dsimpson.home.infi.net/Volvo_610.html
and am selling my F-250.
et cetera
South-East
Posted: 02/14/03 04:44pm Link  |  Print  |  Notify Moderator
cwil59,
What kind of engine do you have in it?
http://www.trailerlife.com/output.cfm?id=42175
*This Message was edited on 14-Feb-03 04:46 PM by et cetera*
Sublime
Santa Fe, New Mexico USA
Posted: 02/14/03 04:49pm Link  |  Print  |  Notify Moderator
I believe that the numbers are "Gross Combined Weight". So that might be with the truck and camper fully loaded.
But I don't know for sure.
1999 Ford PSD Auto Trans. 4x4 SuperCab
2004 Lance 835
"Yes I am a pirate, 200 years too late"
NRA Life Member
