RV.Net Open Roads Forum: Tech Issues: Shower Floor Crack
 > Shower Floor Crack
dix
Tucson, AZ
Posted: 02/18/03 08:33pm Link  |  Print  |  Notify Moderator
I was stumbling around the RV this weekend and noticed a crack in the floor of the shower stall. Never noticed it before. It's about 4-5" long, a gradual arc shape, about the thickness of a 2-razor blades. Any tips, short of replacing the shower, on how to make a lasting repair?
Reply directly to leafman@worldnet.att.net
Thanks
RickL
PS - thanks for the many replies on my 30-50 amp question.
Kajtek1
CA
Posted: 02/18/03 11:42pm Link  |  Print  |  Notify Moderator
If this is only hair crack and is only on the surface (not thru) - you don't need to worry about it.
If the crack is thru - the recommendation is to replace the pan. It can be repaired with epoxy resin, but it is not going to be very cosmetic.
dix
Tucson, AZ
Posted: 02/19/03 08:07pm Link  |  Print  |  Notify Moderator
Thanks for the info. I was considering a fiberglass repair kit...just wnated to confirm I was on the right track. Thanks for the info.
craig7h
Branson MO area
Posted: 02/19/03 05:09am Link  |  Print  |  Notify Moderator
I have had the same problem, my shower stall had a crack running from the drain out about 5 inches. I used a fiber glass repair kit. Sanded the shower floor and applied the glass, it has stayed water tight for many showers. Yes its not pretty, but was not in for replacing.
craig
35' Southwind
cdowns1
On the road
Posted: 02/19/03 05:41am Link  |  Print  |  Notify Moderator
I had to fix one in my previous fiver (Terry), fiberglass repair kits work just fine. And as fas as asthetics, who will see it besides yourself?
Charlie
06 LBZ 3500 Dually Chevy CC, 4WD, Locking differential, 2005 Carri-Lite 36KSQ. Charlie, Barb and the Boss (Jacque, a spoiled brown poodle) at Blue Spruce RV, Florida, Indiana, New York, Minnesota and who knows then back to Lake Medina, TX for the winter.
cmoehle
San Antonio, TX
Posted: 02/19/03 05:57am Link  |  Print  |  Notify Moderator
If under warranty, replace, else patch. Thing is, what caused it? I can think of two reasons: 1) Over tightening the shower tub drain, or 2) the shower tub is not seated properly. Avoid 1. If 2, seat it properly before patching or it will crack again.
VanMan
North Central Texas, USA
Posted: 02/20/03 09:39am Link  |  Print  |  Notify Moderator
I repaired a MAJOR crack in our previous TT. Fiberglass resin + matt and cloth. I removed the tub/shower bottom, taped over the crack, then flipped her over and away we went ! probably an overkill but when I fix something, it STAYS fixed !! While out I vacummed up shavings, etc, from the original fabrication, caulked any little places the mfg. should have and installed some roach,ant,mouse deterrent stuff.When reinstalling, I placed a large piece of heavy styrofoam (wood would work but is heavier) under the tub to make it solid, so this would not happen again. Once installed, I removed the tape and touched it up with almond peorcelin repair paint (like for a refrigerator) and you would never even no it had a crack !!
1999 F-250 SD/SC V-10 Lariat
2000 Montana Mountaineer 305FKS
1992 GMC 2500 Conversion Van 350TBI
Shipper
Lower Alabama
Posted: 02/20/03 06:45pm Link  |  Print  |  Notify Moderator
Almost every town has at least one person who repairs fiberglass and will come to the job. I have had several tub/showers repaired in rental houses that looked like new. If you ever intend to trade units, it will be money well spent. My experiences averaged about $75 a repair. Good luck
"I'm not insensitive, It's probably that I just don't care!"
clffhnger
Thousand Jokes CA
Posted: 02/20/03 07:34pm Link  |  Print  |  Notify Moderator
As I was reading this post, that same thing came to mind. I usually pay 50-75 bucks for fiberglass tub/shower crack repairs and my guy does them so you cant see it when its done.
NeedinPower
Beaver Dam, WI
Posted: 02/19/03 10:08pm Link  |  Print  |  Notify Moderator
Could coat the entire inside of the shower base with an elastomeric compound,like a sealer used on parking decks. It would look nice, outlast the RV, and you can add some non-slip texture grit to make it safe.
2006 Dodge Ram 3500 MEGA Cab 4x4 CTD
2002 325 Jayco 5vr
Typical loading: Wife/3kids/lots of beer
