RV.Net Open Roads Forum: Travel Trailers: Leaking shower enclosure
 > Leaking shower enclosure
Travel Trailers Related Tips
Btravelen
N. IL
Posted: 04/10/03 10:49pm Link  |  Print  |  Notify Moderator
Has anyone disassembled the 'accordion' shower curtain enclosure on their rig? Mine leaks around the front lower corner. It has leaked from the factory, and still leaks after a feeble attempt at a warranty repair. The dealer said on the work order that they disassembled it and resealed, but there is no evidence that they did. All that was apparent was a poor job of recaulking. I hate taking my things in for someone else to work on. I'd rather do it myself!
2000 Ford Excursion V10 (SOLD) 2005 Exc. 6.0L PSD, 2wd, 3.73LS, Air Lifts with Load Controller II, towing '00 31SKS Holiday Rambler Alumascape with a '01 Hensley.
JR323
Temple, TX
Posted: 04/11/03 02:10am Link  |  Print  |  Notify Moderator
I have had mine leak between the tub wall and the pleated shower curtain mount. Caulked this and no more problem there. You might also want to check that the water isn't splashing down and back out where the pleated shower curtain sits in the rail. Mine did this, apparently the pleated door wasn't set deep enough into the track. Just put up a regualr shower curtain and all my problems went away.
*This Message was edited on 11-Apr-03 02:10 AM by JR323*
2004 Chevy Suburban K2500 8.1L with 4.10s
2004 Jayco Eagle 298BHS
Prodigy
Tote Tank Carrier www.PictureTrail.com/gid6040203
Jayco Add On Sliding Doors www.PictureTrail.com/gid6922763
Jayco Custom Built Corner Shelf for TV www.PictureTrail.com/gid7937952
GACamper
South Georgia
Posted: 04/13/03 08:06pm Link  |  Print  |  Notify Moderator
Our leaked also at both ends. I caulked around the inside and outside edges. I also caulked the inside of the ends. The side the shower curtain is attached you can pull the curtain back enough so you can caulk the inside seams. You might want to caulk up the wall of the inside seams on both ends also. That should take care of your problem.
*This Message was edited on 13-Apr-03 08:08 PM by GACamper*
2007 Keystone Cougar 311RLS
04.5 Dodge Ram 3500 Cummins 5.9L,
Striker II Power Module, Holley Blue, Cat 2-Micron Fuel Filter System, AFE Pro-Dry S Air Filter, Intake Eliminator Pipe, Muffler Delete Pipe>>>"Still Tree Hugger Friendly"
