RV.Net Open Roads Forum: Class A Motorhomes: Honda CRV as a toad
RV.net
 > Honda CRV as a toad
hackalar
dickson tn usa/ from panama city fl
Posted: 04/19/03 03:06pm Link  |  Print  |  Notify Moderator
since i'm new to this i need some help. i'm getting ready for my first real trip. its about a 5 hour drive. Cant wait!!! but anyways here's my question,i have a 1986 fleetwood bounder 30 ft and i need to pull a toad. i also have a 2000 honda CRV 4 wheel drive. i'm thing about renting a dolly from u haul and pulling the honda. is this ok? is the dolly what i should use? would it be ok to pull the honda with out doing any damage???? thank you so much!!!
1986 31 foot fleetwood bounder
A 27 year old bum living in a motor home. separation does that!!
RVmom
Stockbridge, GA USA
Posted: 04/19/03 03:33pm Link  |  Print  |  Notify Moderator
I saw another post under the dingy towing section that gave a link to www.towingworld.com/towables.html (I think this is correct). I believe they said not to tow it on only two wheels. From that you would need to get a towbar and pull it on all four. The nice thing is that towing four down is easier than fooling with a tow dolly, but it also means you can't just rent the equipment.
Go to your owners manual and verify the information from them on any procedures.
Jeff and Janet
2003 Monaco Monarch 34'
2 kids
2 Basset hounds
1 cat(not about to get in an RV with 2 dogs)
Stockbridge, GA
No we can't stop at the next rest area!
exportman
Clovis, Ca
Posted: 04/19/03 03:40pm Link  |  Print  |  Notify Moderator
There are many posts and comments on this subject in the "Dinghy Towing" section of this forum that deal with, gross vehicle weights, combined vehicle weights, Hondas (which are usually all towable 4 down (providing you follow Honda's procedures), tow bars, etc. Suggest you search there and click the "last 6 months" box and you will find a library of information.
The short answer to your questions are yes, you can tow a Honda CRV without a dolly; if you use a dolly (trailer) you add a lot of weight and you always have the nuisance of where to put the trailer when you stop. Also, check out your vehicle weight, add this to your dinghy weight and the two should not exceed your maximum allowable weight. My guess is that your combined weights will be within the limits. I assume you have the Chev 454 engine or Ford's equivalent.
On edit I noticed one of your specific questions was whether the CRV could be towed with only 2 wheels down. Don't know about that.
*This Message was edited on 19-Apr-03 03:42 PM by exportman*
Bronco2
Gloucester, Va. 23061
Posted: 04/19/03 03:44pm Link  |  Print  |  Notify Moderator
The CRV is an excellent Toad for towing four down. Don't know about towing on two. Get the tow bar and turn/brake light kit and set it up up for towing on all four. It is much easier especially when unhooking at a campground etc. You don't need to unhook and store a dolly also. As long as you already have the CRV, my opinion is that's the way to go.
--Happy Travels--
Ralph & JoAnn
2004 Cardinal 29WB
2003 F350 4X4 CC PSD 6.0
Florida Cracker
Titusville FL, USA
Posted: 04/19/03 05:03pm Link  |  Print  |  Notify Moderator
You can't tow a 4wd CRV with 2 wheels down, 2wd models are OK but you have to use 4down or a full trailer for the 4wd. 4 down is by far the easiest anyway. Enjoy your CRV, they make wonderful toads.
Bill
(And one spoiled rotten little dog)
big jimbo
Carson City, NV/Surprise, AZ./Florence,OR
Posted: 04/19/03 05:22pm Link  |  Print  |  Notify Moderator
I am towing a 99 CRV with all four wheels on the ground and have had no problems. Florida Cracker doesn't know what he is talking about.
I do have three different pieces of literature that give three different procedures, but what I do is start the toad every day, if you don't unhook, and run it through the gears.
One thing that all of the info I have agrees on is to go to Neutral from Drive. If you go from Reverse to Neutral you will do serious damage.
If you need further info, feel free to e-mail me.
Jim and Sally and a Lakeland Terrier named Rufus
Carson City, NV/Surprise,AZ/Florence,OR
2001 Country Coach Affinity, 40'
Towing a 2005 Ford Explorer Sport Trac with a Blue Ox tow bar and using a Brake Buddy.
pulsar
Lewisville, NC
Posted: 04/19/03 05:54pm Link  |  Print  |  Notify Moderator
I guess Jim_Harper misread Bill's (Florida Cracker) post. Anyway, they are both correct. A 4WD CRV must be pulled 4 down or all 4 on a trailer. Ours has a manual transmission, which simplifies things - there are no warm-up procedures. If yours is an automatic, follow the instructions in your manual and you will have no trouble.
Tom & Sarah
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Indiana Jones
INDIANA
Posted: 04/19/03 06:15pm Link  |  Print  |  Notify Moderator
Our 2003 CRV automatic tran 4 down or on all 4 on trailer.
Jack and Juanita
Florida Cracker
Titusville FL, USA
Posted: 04/19/03 09:31pm Link  |  Print  |  Notify Moderator
Jim_Harper-
Reread my post before you mouth off, The 4wd CRVs must be towed 4down or all on a trailer. If you only have the rear wheels down and the front wheels on a dolly you will tear up the transmission. I just rechecked my manual to make sure I wasn't mistaken.
BIGDOMINO
Full Timing since July 13th 2007
Posted: 04/20/03 08:34am Link  |  Print  |  Notify Moderator
As you habe seen from some of the other notes, you can not pull a CRV 4x4 on 2 wheels. I pull a 2001 CRV with automatic trans. Works well. You must go thru the routine the factory tells you to do. Takes a couple of minutes and you are ready to go. Tows well. Don't know it is there.
Good luck!
Steve & Toni__
38 foot Monaco knight with every option available.
2001 Honda CRV in tow.
Wife running the show.
95 pound Golden named Max loving the ride.
FULL TIMING AS OF JULY 13, 2007
