steve-o
Blandinsville, IL
For the past week, an odor (holding tank type of smell) has developed in the area beneath the kitchen sinks. It is getting stronger by the day. What could cause this, and how to fix? It is not a dry trap since we use the sinks daily. Appreciate your help.
Thanks - Steve
bigdaddy & littlemama
Carthage, TN
You might check the under sink vent. It is a one way vent valve or check valve, lets air in and not out. Most are nothing more than a rubber flapper and may be stuck in the open position. Look at the drain, it should be at a level above the goose neck.
bigdaddy & littlemama and "Miss Lucy & Chucky"
'02 Allegro Bay 35DB W22
"07 X Unlimited Wrangler
'05 Harley Trike
Our other coach is a school bus(yes, we both drive)
Dacam
As the previous post said Check the under sink anti-siphon Device.This is what it looks like.
Go here and look up plumbing vents and you can see a picture of what one looks like.
(1)Click on link below
(2)Click on (RV Parts and Accessories)
(3)Click on (Plumbing-sanitation)
(4)Click on (Sanitation Vents)
(5)Click on (vent pro more information)
http://www.dyersonline.com
*This Message was edited on 31-May-03 11:19 AM by dacam*
Wheelman
Pleasanton Ca.
Check under the sink and cabinet for a dead mouse.
Mr_Pace
Land of Enchantment
Hey Steve,
I can relate to the bad odor from under the sink. One time long ago I had an odor that kept getting worse. I could see nothing under the sink. Finally, when I pulled out ALL the adjacent cabinet drawers I found a small sack with four very rotten lost potatoes! They smelled like my Army boot sox after a 50 mile hike.
It may be time to check your spuds! Good Luck.
"I'm gonna keep travlin 'til I find someplace to go!"
Mr. Pace, said that!
Diesel-Lover
SW OH!
Lost Garlic may behave similar to the lost spud patrol!
Phil Rob
San Antonio, TX USA
You might also check to see if you have a propane leak. That smells like black water too. Have had that happen.
