RV.Net Open Roads Forum: Tech Issues: Accumulator for water system
RV.net
 > Accumulator for water system
ChuckA
Posted: 06/01/03 09:45am Link  |  Print  |  Notify Moderator
I'm going to get one to be rid of the pump cycling so much, but what size works out best? Too small and the pump may still cycle too often. Too big and the pump may run too long.
Life is Good
Best improvement, wife 2.0 21 FANTASTIC yrs ago
2001 35' Georgie Boy w/V10, 220watts solar w/SolarBoost 2000, 4-T105 batteries, Trimetric
Saturn Vue Hybrid toad w/Falcon bar & Brakemaster
BlueLogger
bluesky
South Jersey
Posted: 06/01/03 10:03am Link  |  Print  |  Notify Moderator
As a guideline, a one-gallon accumulator will send out a quart+ of water before the pump kicks in. You can take it from there.
Dino
1997 Ford Expedition 5.4L with RS9000X Ranchos and Prodigy
1998 Sunnybrook 24FB with Hensley Arrow
homepage: Low-Tech Ideas, Tips, Hints and Solutions for RV Trailering
"Please RV Safely and Courteously"
Pull-Tab
Central Ohio
Posted: 06/01/03 10:36am Link  |  Print  |  Notify Moderator
I recently installed a 2 gal. It works well without running to awful long to refill (maybe 45 secs or so) be then you can use quite a bit before it kicks on again. Biggest advantage is the cold water pulses in shower are now gone. BRRRRR!!!!
6.7 Cummins Turbo Diesel/Heartland Bighorn 2925/Garmin 2610 GPS/
Rally attendance "10"
Kajtek1
CA
Posted: 06/01/03 01:22pm Link  |  Print  |  Notify Moderator
Buy Sensor VSD™ Pump
The water tank accumulators becomes obsolete with new technology.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
96Bounder30E
Orange County, CA
Posted: 06/01/03 01:31pm Link  |  Print  |  Notify Moderator
Maybe so...but who wants to spend a car payment on a Galley Pump???
Kajtek1
CA
Posted: 06/01/03 02:35pm Link  |  Print  |  Notify Moderator
You can trade your Bounder for Chinook
Read what the others say about the pump
Just finished installing it and had to share! This pump is better than anything written about it. I was hesitant because of the cost, but after turning everything on, there was no noise coming from the pump! Further, when turning everything on - there was no drop in pressure - anywhere! Get it - you will not be disappointed!
DJones
Lakeside, Arizona
Posted: 06/01/03 06:40pm Link  |  Print  |  Notify Moderator
Try this site. I installed one and it works good.
http://rk-enterprises.home.att.net/accumulatortank.htm
Lug_Nut
Newmarket , Ontario, Canada
Posted: 06/01/03 07:41pm Link  |  Print  |  Notify Moderator
I'm confussed. I'm on my 3rd motorhome and I've never owned one that did not already have an accumulator. What's up with that!
'07 Newmar Essex 45' ISM 500 4 slides
Kajtek1
CA
Posted: 06/01/03 09:06pm Link  |  Print  |  Notify Moderator
The are the "selling point" for more expensive coaches I guess.
Just like the daytime running lights in California.
ChuckA
Posted: 07/16/03 03:21am Link  |  Print  |  Notify Moderator
I did install the 2 gallon stainless steel one from Campers Choice, and it works great. Before we go to bed at night, we shut off the water pump, it's under our bed, and the accumulator supplies enough water for the entire night. No pump noise in the middle of the night!
