RV.Net Open Roads Forum: Travel Trailers: Frig on with propane on the road??
 > Frig on with propane on the road??
Slowmover
Fort Worth, TX
Posted: 07/30/10 07:04pm Link  |  Print  |  Notify Moderator
Saw an installation recently (on a 1985 Silver Streak) where the owner added an XHD cable from the batt/alt to run his three-way reefer. Hoping to hear how it works, as it "might" be an "answer" to the "problem" of running propane while underway.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
cajoctaw
Hattiesburg, MS
Posted: 07/31/10 03:20am Link  |  Print  |  Notify Moderator
We leave ours on propane and use the "auto" switch.
I agree.... "let the fridge decide".
As already stated, MOST of the RV'ers travel with propane ON.
There is exactly ZERO cases of it causing a fire or incident in the national Fire records.
twaldher
Bremerton, WA
Posted: 07/31/10 09:13am Link  |  Print  |  Notify Moderator
I always ran with the propane fridge on, never bothered turning it off to fuel up either.
Why?
Even a short 19' trailer has the pilot flame at least 19' away from the filler on my truck, and not only that, probably 3' off the ground.
I challenge people to find a confirmed case of an RV propane fridge setting off an explosion of fuel vapor at a gas pump. It's going to be way easier to find people setting off explosions via static electricity getting in/out of their cars while fueling.
Why don't I know? No longer own the trailer.
1998 Chevy Crew Cab 4500 4x4 454, Auto, 4.10 Gears
2003 Nomad M-308 (30', bunks, 14' slide)
Prodigy P3 Brake Controller
Rogue Agent
Brookville Pa
Posted: 07/31/10 11:56am Link  |  Print  |  Notify Moderator
I run mine off the propane for a long trip,my fridge is also a 2 way but I wonder if you back feed a 700 watt inverter into the 110 system by using 2 male plugs would that be enough to run the fridge on 110 and your alternator recharges the battery while your driving. I am thinking the heaters might be 2 much draw on the system Has anybody ever consider this ? I was curious if anyone had tried this ? Could be a new science experiment if anyone has tried it let me know how it worked out.
PS: the 700 watt inverter I hard wired into the system. I use it to run my computer when I am dry camping.
trkr33
home
Posted: 08/01/10 05:39am Link  |  Print  |  Notify Moderator
i always run with propane on on road too. if your afraid of explosion then you better just take tanks off camper because you never know when you will get in an accident and tanks will blow up. stuff will happen and you hope for the best that's all you can do!
