RV.Net Open Roads Forum: General RVing Issues: Fridge on while driving?
 > Fridge on while driving?
Travel2
Syracuse, NY USA
Posted: 10/23/04 09:00pm Link  |  Print  |  Notify Moderator
Newbie here. Can you leave the fridge turned on while driving? This was discussed before but couldn't find the forum when I searched. I heard that your not supposed to. Thanks
If you always do what you always did; you'll always get what you always got. Try something new!
2005 Four Winds 5000
Roadmaster All-Terrain Tow Bar
2003 Pontiac Montana Van Tow Vehicle
jdcone
Riverside, Ca. USA
Posted: 10/23/04 09:02pm Link  |  Print  |  Notify Moderator
Just remember to turn it off when refueling, and you'll be fine.
Owners of Bob the Wonder Dog, and a bunch of other useless stuff.
1999 22' Tioga class C
retired logger
WA USA
Posted: 10/23/04 09:15pm Link  |  Print  |  Notify Moderator
Mine has been on three years steady (24/7) now on this rig.
Short time young and a long time old !
Reddytoroll
Bella Vista, AR, USA
Posted: 10/23/04 09:53pm Link  |  Print  |  Notify Moderator
Sure, we leave the fridge on, but when we pull into a gas station, my wifes job is to turn it off and then wait until I fill up. Then I bang twice on the TT, and she turns it back on and awaaaaaay we go!
Bob and Barb
2005 Rockwood 2304S
1999 Chevy Van Conversion Van
Equalizer WD hitch
Prodigy Brake Controller
dolphin1
Clovis, CA.
Posted: 10/23/04 10:26pm Link  |  Print  |  Notify Moderator
When traveling to and fro, we leave are Fridge on. Been doing it for nine years now. I use gas in the winter and generator in the summer, i use the roof air in the summer too.
Dan from Clovis, CA.
1996 Dolphin 35' tag axle
460 F-53 super duty Ford chassis/one slide
Banks power pack, trans module
PML covers,Air lift air bags
full R/P synthetics,IPD Bushings
Bilsteins and K&N air filter
Safe-T-Plus steer shock
98 Honda CR-V toad
Momma
Eastern Oregon
Posted: 10/24/04 12:05am Link  |  Print  |  Notify Moderator
Those that leave it on are people who are looking for trouble. It only takes once to burn your rig to the ground. I know they will tell you I'm crazy, but I've seen it happen. I fought the fire and the town got a new gas station. With a five thousand gallon propane tank with in 15 ft of the MH, I would say we are lucky only the station and the MH and the UPS truck burned up. I say get some small reusable ice packs and put them in the refrig while traveling and put them back into the freezer at night to refreeze ready for the next trip.
Mrs. Mik
Abbotsford, Wisconsin
Posted: 10/24/04 12:28am Link  |  Print  |  Notify Moderator
Sounds to me like someone didn't turn off the FRIDGE when refueling and that's what caused the problem. The SPARK from the fridge, not the propane itself.
Kittytwo, if you are REALLY interested in the TRUTH about traveling with the propane running, read the following information. It's long, but well worth the read. Knowledge is power -- some folks just refuse to learn.
Anyway, here is the REAL DEAL when it comes to propane safety:
I "borrowed" the following answer from the IRV2 website, written by RV Roadie. This is by far the most thorough and comprehensive answer to the question of whether or not to run with the propane on. It's rather long, but well worth the read!
Thanks RV Roadie!
I called the Oregon DOT and confirmed that when fueling, all open flames and sources like the engine, must be turned off. However, they stated that there have been no incidents where running with the propane on, have contributed to igniting an RV fire. They also confirmed that they see no problem with running on Oregon roads with propane appliances running, as long as they are turned off before refueling with any type of fuel. This was confirmed by the state fire marshal.
In Oregon, there is no rule against having your propane on while traveling in their state. This is directly from Oregon NFPA Code and was confirmed with the Oregon DOT today, and through the Oregon Fire Marshall's office.
The source for the information is the Oregon DOT and you can call them toll free at 1-888-ASK-ODOT to confirm for yourselves.
Here is a reprint from the email I received from the Oregon DOT supervisor:
"All ignition sources must be extinguished while fueling the vehicle, however
there is no prohibition against having a lit reefer while in transit."
Which is what we have been proposing here the whole time. The facts. Whatever your choice, extinguish all open sources of ignition before fueling, especially at islands with gasoline.
The above is a synopsis of information from authoritative sources, which are listed below.
My summaries of the data are these:
1. Running with the propane valves on could increase the risk of the propane igniting during a travel accident, but that risk is slight, and in the "catastrophic" scenarios listed, almost equal for valves off as valves on. If a rollover or severe collision occurred, not only could the gas lines rupture, but the tank and the lines at the tank could also, not to mention the heat from a fire. Conclusion: Running with the propane on is OK, from the experts. Risk increase slight, and doing it or not is a personal choice.
2. That the reefer and other appliances are indeed open flames and could ignite the gasoline vapors. And, since it is against the law to have any open flame, they must be turned off before refueling. The law does not state that there are exceptions for people that disagree, or know that gasoline vapors are heavier than air. As in all cases, some will disregard, and maybe even get caught, perhaps even be the one case we finally hear about. That decision is the same as drinking and driving. If caught, not much room to complain. Turn em off when refueling.
3. That most people are unaware of the real hazards for ignition of gasoline vapors, which are more than likely to have been responsible for any ignitions they have heard about or seen. These include hot brakes, catalytic converters, hot trannys and exhaust systems, that have not even been mentioned here, except briefly and accurately.
4. Since the original question was about a way to run the reefer from another source for safety, and since most folks will not discard a perfectly good reefer and spend $1500.00 or more for a three-way reefer, can it be done? Well, not from the inverter, but for all those that want the ultimate in safety, and not worry about shutting down the propane, in researching this answer I did find one possible solution. It is a switch that shuts down all propane when you switch off the ignition, and can be activated manually as well. Might be good or junk, I don't know, as I haven't tried one, nor can call them today, but just as a possible good compromise, worth looking into if only for an interesting compromise device for under 100 bucks.
If my conclusions are not what you wanted to hear, please read the below sources, and perhaps some of them will become clearer. For those that want to have no safety risks, driving multiple tons of rig down the road is also a bigger risk than not. However, for those interested in real fire and refueling safety, the below may add a few items to your refueling and travel checklists.
Article on other fire safety hazards you might not have considered
http://www.rvaa.com/articles/safe_fuel_pump.php3
Recommendation for turning off all propane appliances before fueling, did you know you need to fully open the propane valves for the excess flow valve of your tank/s to be operable?
http://www.rvaa.com/articles/propane2.php3
More fire safety for RVs and diesel Vs gasoline vapor points
http://www.wbcci.org/html/body_maintenance_tips.html
Maybe a 94 dollar solution?
http://www.lslproducts.com/FOPage.html
Gasoline vapor flash point and concentrations
http://www.chemistry.ohio-state.edu/ehs/handbook/flammabl/firetech.htm
Gasoline heavier than air and pools in low spots as well as running along the ground to ignition sources. Diesel fuel needs above 100 degrees to even produce vapor.
http://www.eig.com/ssus/ssu9706.html
┬ęDerek Gore / RV Roadie 1998-2002
OK here is the last half with all the hard info, we'll see if it all goes:
Propane 101
So why all the tales of accidents and propane lines spewing? Actually it was true at one time, but times have changed along with the equipment.
Prior to 1977 the majority of connections between the regulators and the propane containers (pigtail) in RVs were made of copper tubing, and were wound in a coil to take up excess tubing creating the "pigtail" coil appearance, from which they got their name. Copper, being malleable, when strained to breaking will many times reduce the inside diameter of copper tubing, either from stretching, or bending. This can restrict the flow to the point that excess flow check valves, which reduces the pressure in the propane line in case of a break or leak in the line, might not detect excess gas flow. Thus full pressure flow could occur.
In 1977 the code was changed mandating that the connections, or pigtails, between the propane container and the regulator be made of rubber and then thermoplastic tubing, which would not change diameter in a mechanical "accident," and would activate the excess flow valves reliably when torn apart.
It is important at this point to clarify terms. A tank is not a cylinder and vice versa. A propane cylinder, is a removable container like used in 5th wheels, TTs, and BBQs. It is not permanently mounted. A Tank refers to a permanently mounted propane container, like in a motorhome. My fiver uses a cylinder; your motorhome uses a tank.
Here is the very important distinction. A tank has a permanent connection to the Motorhome's propane system, and has an extra fitting for it to be connected to at fill stations. The connection between the tank and the MH's propane system is never disconnected, except by a professional technician in most cases.
With removable cylinders, the owner, a non-professional disconnects the cylinders, whenever a fill is needed. Thus the new valve design, and extra safety features, to prevent accidents by the end user while removed, during filling, and during removal and reinstallation of the pigtail from/to the cylinder.
The MH tank is an ASME (American Society of Mechanical Engineers) design and does not require the new OPD (Overfill Protection Device) valves because it already has a check valve and overfill protection, albeit a different design than cylinders.
The trailer cylinders are DOT (Dept. Of Transportation) and have additional safeguards in the OPD and the pigtails because, as said earlier, they are disconnected completely on a regular basis by the user. These are in the 4-40 pound capacities. (Usually 30 pounds on fivers, and 20-pound cylinders on some TTs.)
Several changes have been mandated for DOT cylinders since the pigtail mandate. In 1998 it was mandated that hand screw on Acme nuts be used on the pigtails in place of the older POL (Named after the company that designed them, the Prest-O-Lite Company) connectors. The Acme nut is the part that screws into the cylinder, and takes the place of the older brass POL connectors that screwed into the cylinder valve with a reverse thread requiring a wrench to tighten and seal. The Acme nut is the new Green one that screws onto the OPD's outside thread, uses a normal right hand twist to tighten, and which also tightens to seal by hand only, not requiring a wrench. This is significant because two safety features are built into the Acme nut itself. First, Acme nuts contain a thermal bushing, which will melt in a fire, and prevent the escape of gasses from the tank. When it melts, it allows the new OPD spring activated shut off valve, which will only allow the flow of gas if a fitting is attached, to pop out and completely shut the flow down. They also have an improved excess flow check valve, compared to the valve in the old POL fitting-more on that later. The new Acme nut also adds an O-ring to further help prevent leaks at the connection.
With the advent of the requirement for all 4 to 40 pound DOT cylinders to change over to OPD valves in 2001, the safety features, in addition to the spring loaded shut off valve, have been further enhanced by insuring that the cylinders cannot be filled over 80% of capacity. This allows for vapor expansion, without building up excessive pressures from overfilling, and venting by way of the pressure relief valve. The old overfill device was a tube that connected to a bleeder valve that was observed during filling for liquid emission which indicated 80%. But if the person filling it did not shut off the propane it could overfill anyway. They used a scale for weight to fill also. Now DOT cylinders have an automatic stop fill valve built into the OPD valve.
The ASME Tanks for MHs did not require a change in valve on the tank because they already had sufficient check valves for excess flow, should there be a leak or sudden break in a line. And for more than 17 years, ASME tanks have used automatic stop fill valves to limit filling to 80%. Why so long before DOT cylinders? Because you can't remove them to verify the fill by weight! More importantly, since the connection between the tank and the MHs system is not broken, there is no need for the spring-loaded valve that the DOT cylinders had added with the new OPD valve. That valve prevents the gas from coming out of the cylinder unless there is a tight connection made from the POL or Acme nut depressing the valve. In other words, you can turn on the valve of the DOT cylinder, and no gas would come out unless there was a connector depressing the inside valve. Not necessary for MH connections that are never removed. Thus they were exempted from the OPD changeover rules.
Now to the new style excess flow check valve on the Acme nut that connects to the DOT cylinder's OPD valve. It is really a simple device. Inside the Acme nut, there is a ball bearing check valve that almost shuts off momentarily when full pressure is released by opening the cylinder valve. You should hear a click at that point. It doesn't shut down completely, as that would negate its ability to detect leaks and excess flow from a leak or major line break, and no gas could flow. It closes just enough to allow a bypass of gas that is very slight, about 10 cubic feet or less per hour (cf/hour) flow, as opposed to the max flow of 200 cf/hour. The bypass gas goes into the propane system, and if there are no leaks or broken pipes, it backs up and builds pressure in the gas lines in the RV. When it equalizes on both sides of the valve, the valve opens to allow full pressure up to about a max of 200 cf/hour at 100 psi. Then if you were standing there, you would hear a second click. Using all of your propane appliances should not exceed 100cf/hour. If there is a leak or a broken pipe, the pressure can't build up and the excess flow valve doesn't open up all the way thus limiting the gas output to about 10 cf/hour, or less. It is important to note that propane, like gasoline vapor, has narrow ignition requirements as far as air fuel mixture is concerned. So if you lit the leak (Don't try this at home!) it would show a flame at the leak in the air, but the concentration is too high in the line for it to ignite. In other words the fire can't run up the line to the cylinder or tank to ignite it. Want to see it in action? Watch your gas range work. Why doesn't the flame travel up the tube it comes out of to the burner? Same thing.
In fact, it is pretty difficult to actually blow up a propane tank or cylinder. What does occur when the pressure relief valve blows, which occurs at 312 psi in ASME tanks, and 375psi in DOT cylinders, is that the gas is vented and makes a lot of noise. I have had one overfilled tank vent and it really got my attention! But there was no flame or problem, as it dissipated outside very quickly. Should there be a fire or source of ignition when it vents, it won't explode either, instead it makes a torch. It does not ignite inside the gas line and run up it to the tank or cylinder and "explode." The only exception to that, is if it is punctured and ignited simultaneously, and then the same external ignition occurs only more rapidly. Or, if a leak is allowed to build up inside an enclosed space like our RVs, and then is ignited, there is one heck of a fire. But oxygen must be present in the right mixture within the ignition range, which is fairly narrow. The important thing is that with the garlic odorant (Ethyl Mercaptin) that is added, you would smell it in most cases of a small leak or break, with time to take appropriate action. It can be smelled by the human nose and your detectors at about 1/5th of the lower limit of combustibility or about 1/2 % propane to air. (Propane combusts at 2.15% gas to air to 9.6% gas to air - not above and not below.) Since most RVs have propane detectors near the floor now, they would alert long before the levels reach dangerous concentrations, if they are in good working order.
An interesting side note is that there are two types of pigtail connector designs to attach to a DOT Cylinder. Appropriately called Type 1 and Type 2. Type 1 is the Acme nut on the pigtail and the OPD valve on the cylinder. Type 2 is a quick-disconnect (QD,) which requires the type 2 OPD Valve that matches it on the DOT cylinder. What makes the Type 2 different from a plain quick disconnect, aside from needing the valve that matches on the cylinder, is that the Type 2 QD has all the safety items built into the pigtail end as the Type 1. This includes the excess flow check valve, and the thermal bushing.
For some reason, unknown to the industry, when the new code was formulated, RVs were left out of approval for the Type 2 valve and pigtail design for a quick disconnect at the cylinder. It is important to note that this part of the code limits only the main connection from cylinder to pigtail to regulator to a Type 1 in RVs. It is acceptable to use a plain propane approved QD for a tap in the line after the regulator in an RV, for example to run a line to a BBQ grill or Catalytic heater.
In summary, while some people have experienced propane leaks and breaks in the lines, there are safety devices that you never see, and most folks are unaware of, that stop or limit the flow in a mechanical leak, fire, or breakage. With today's built in safety systems, propane detectors, and the final back up, our own noses, it is much safer to use and live with propane than ever before. Should you have a sudden low-pressure condition in your RV appliances, it may be that the excess flow check valve has kicked in and is telling you that you have a leak or break in the line because it would not equalize. Of course to test that, all you have to do is turn the propane off at the cylinder or tank, wait a few minutes and turn it back on to full. If it then equalizes and runs OK, it just had a piece of trash or contaminant that temporarily hung up the excess flow check valve. That click you hear is the check valve operating when you first open the cylinder valve all the way. It is possible to turn it on so slowly that you won't hear it, but in most cases you will with the new equipment.
If you plan to run your fridge on the road, and still have the old design pigtails and valves on your DOT cylinders, you might want to consider changing over for maximum safety. (Yes, in some states like Louisiana, you can still fill non-OPD DOT cylinders.) Now that you know how the check valves work, you know that it is very important to keep the inside of the cylinder valve clean, to avoid getting grit and road grime from fouling them and possibly getting into the excess flow check valve when reconnecting. Looking at the valves that are exposed when transporting your DOT cylinders for refilling, it is very important to use the plastic plugs for the old style valves, and the caps supplied with the OPD valves on the cylinders when transporting them to and from the refueling station, to keep contaminants out of your safety devices. Also keep them upright at all times. This keeps them from possibly leaking liquid propane. I use an old plastic milk crate for transporting that keeps them upright and stable enough not to fall over with reasonable driving. The 20, 30, and 40-pound cylinders all fit in them snugly. For the taller tanks, an additional strap or bungee cord might be necessary.
None of these precautions or items will make it safe to have an open flame (propane appliance running) while refueling with any fuel, especially around gasoline vapors. Also remember that it is not necessary to turn off the propane before fueling, assuming your system is in good shape with no leaks, but to turn the propane appliances off electrically, by using the on/off switches inside. With the electronic igniters used today, should one go into auto ignite mode, either by design or malfunction, that could ignite gasoline fumes as well as the flame. If it makes you feel more secure to shut the propane valves off as well, that is fine. Just remember that the excess flow check valve insures no leaks, if the fridge was operating properly at the time of shut off.
I have not even gone into all of the propane and ignition safety devices that cut off the gas supply at the appliance for under and over pressures, and failure of ignition etc. Every one of them has those built in as well.
Also remember that all propane appliances generate CO, or Carbon monoxide. That is why they vent their combustion products to the outside, and draw their air for combustion from the outside. They must be sealed from the inside compartment or we would all have CO inside. Should there be a leak outside on the road, the outside vents would probably keep it from reaching any concentrations that would ignite. And the gas should not be able to get inside. If there is a leak inside, it should not be able to be ignited by the appliance flame outside. Any leak is dangerous and should be dealt with immediately by turning off the propane at the source and shutting down any electrical devices that might create a spark.
Understanding all of the above should make it plain why I said the risk in running a reefer on the road is not one of catastrophic danger. And why I say that there is only a slight increase in risk, which is negligible from a fire standpoint based on propane ignitions causing less than 1/10th of one percent of all fires. The chance of a fire from your engine leaking fuel, or an electrical fire, are magnitudes greater. But we start our engines and use our electrical systems.
Again, running the reefer on the road does not include while refueling. Choosing not to run your propane while in transit is a personal preference made with all the facts in hand. Not running it while in transit does add some extra measure of safety. Which is rational, and may make for peace of mind for many folks. But running it or not is not the big risk, or lack thereof, many make it out to be. Whatever decision makes your travel and comfort levels best, is the right one for you. Can mechanical devices fail? Of course! Which ones fail most often has been covered.
I would like to thank the kind folks at Marshall Gas Controls for spending so much of their valuable time with me to provide the history, facts, and figures used in this article. And for finally getting this RVr to understand how that excess flow valve and thermal bushing work.
┬ęDerek Gore / RV Roadie 1998-2003
I have challenged folks to dispute the above facts, and no one has been able to do so. Don't worry about the chicken littles out there!If you follow the appropriate safety guidelines, you will be fine.
Julie Mik
patonica
Los Angeles, California USA
Posted: 10/24/04 12:39am Link  |  Print  |  Notify Moderator
I agree with Readdytoroll. My wife and I do exactly the same show when we pull into a gas station, except I don't knock I whistle instead. [emoticon]
patonica
Posted: 10/24/04 12:49am Link  |  Print  |  Notify Moderator
The name is REDDYTOROLL!!
my apology for the misspelling![emoticon]
2oldman
NM
Posted: 10/24/04 01:20am Link  |  Print  |  Notify Moderator
Srart here
I got this from the FAQ in Beginning Rving. There's plenty more there.
Don't think we need another 30 pages of this subject.
"If I'm wearing long pants, I'm too far north" - 2oldman
