RV.Net Open Roads Forum: Tech Issues: Shower water gets cold
 > Shower water gets cold
moneraipilot
Redmond, OR
Posted: 07/13/10 10:10am Link  |  Print  |  Notify Moderator
When using the shower in our class C, we wet down then stop the water flow with the shower head shut-off. When the shower head is opened again, the water is cold for a few seconds as if the cold water has moved into the hot water lines. Is there any way to prevent this (check valve?) without making it difficult to winterize?
pulsar
Lewisville, NC
Posted: 07/13/10 10:14am Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
TXiceman
Full Time RVer
Posted: 07/13/10 10:18am Link  |  Print  |  Notify Moderator
Install check valves in both the cold water and hot water lines before the shower.
Ken
Amateur Radio Operator.
tmmar
Nassau County, Long Island, NY
Posted: 07/13/10 10:26am Link  |  Print  |  Notify Moderator
Don't shut the shower off completely. Let some water continue to flow and the water temp should stay fairly consistent.
2014 40' Forest River Berkshire DP Bunkhouse
vermilye
Oswego, NY, USA
Posted: 07/13/10 02:44pm Link  |  Print  |  Notify Moderator
In your case the water pressure for the cold water is a bit higher than the water pressure on the hot water side, which is typical. When you shut off the flow at the shower head, the cold water starts to run into the hot water line. Start the shower again & the cold water that filled the hot water line comes out.
The check valve is a one way valve that if placed in the hot water side will let the hot water flow out, but not let the cold water in.
In some cases the problem is the opposite - a blast of hot water. If that is the case, a check valve in the cold water line will solve the problem. Most sure solution is a check valve in each.
They should be placed as close to the mixing valve as possible, and, of course, in the correct direction. They will help if placed further back down the line if you can't get behind the shower.
Jon Vermilye My Travel Blog
My Photo & RV link blog
Fire Instructor
Upstate (Albany) NY Area
Posted: 07/13/10 12:37pm Link  |  Print  |  Notify Moderator
TXiceman - More on your chack-valves answer, please! Where does one get the righght check valves? Do you install them adjactet to the shower valve or along the plumbing run to the shower? Do the check-valves affect flow at all?
Fire Instructor
2014 Ram Laramie w/6.7L Cummins Diesel with Automated Safety Hitch
2016 Jayco 377RLBH
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
robsouth
Metro-Atlanta, GA
Posted: 07/13/10 10:46am Link  |  Print  |  Notify Moderator
Don't turn the water off at all. Just take a quick shower. We do and never run out of hot water with a 6 gallon tank. You can't linger, but you can get a good shower without ever turning the water off at the head.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
rvten
Crossville,TN
Posted: 07/13/10 10:48am Link  |  Print  |  Notify Moderator
This is normal. The cold water line will over power the hot water line when shut off.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
livingaboard
Everett wa
Posted: 07/13/10 10:50am Link  |  Print  |  Notify Moderator
I replaced the crappy shower valve in my rv with a decent one from Home Depot. It is a balanced valve or something like that so that I don't get a rush of hot water or cold water when turning the shower back on.
Dave
Everett, WA
2000 Itasca Suncruiser 35U, F53 Triton V-10
Firestone air bags with Quad control air gauge
Pressure Pro tire pressure monitor
Banks Exhaust
SuperSteer rear trac bar
Olympian Wave heaters (Wall mount and portable)
louiskathy
Oregon (presently)
Posted: 07/13/10 10:51am Link  |  Print  |  Notify Moderator
That's totally normal for us except when we shut it off while we soap up, it goes to really hot and then back to normal.
For a real eye opener, have someone in the kitchen use the water while you are in the shower. Usually it's sometimes-forgetful me in the kitchen area and the forgiving half of us in the shower.
Kathy
