RV.Net Open Roads Forum: Towing: Tadem towing
Search only in Towing
Open Roads Forum  >  Towing
 > Tadem towing
arnoldbennigsohn
Rochester NY
Posted: 07/11/12 11:54am Link  |  Print  |  Notify Moderator
I have a class A motor home and I am planning on towing my jeep wrangler and a small open trailer behind the jeep with my motorcycle on the trailer. Any one out there doing this now. The jeep has it's own set of brakes, the trailer does not, and I won't be over length in any state. (sorry for any spelling issues, had to type fast)
workhardplayharder
Treasure Coast Florida
Posted: 07/11/12 11:56am Link  |  Print  |  Notify Moderator
State by State laws. Lots of post in this forum.
jauguston
Bellingham, WA
Posted: 07/11/12 12:03pm Link  |  Print  |  Notify Moderator
Not legal in many states. In the states that do allow it most require the first connection must be a fifth wheel not a ball.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
JIMNLIN
Oklahoma
Posted: 07/11/12 12:30pm Link  |  Print  |  Notify Moderator
Towing doubles are legal in most states however I would check with the states you will be traveling through for their input on your combination type.
carringb
Corvallis, OR
Posted: 07/11/12 12:32pm Link  |  Print  |  Notify Moderator
Even most states that allow doubles do not allow a 2nd passenger vehicle to be in the middle. Often, it must be at the end of the combination.
I'm not sure the logic however. Cars tend to tow about the same that they drive, so if a jeep can pull a trailer, it should pull a trailer just fine while its being pulled.
I suspect the concern is probably of the strength of connections. All states that allow multiples, require each coupling device to be rated for ALL the weight behind it. That could be hard to do with most tow bars (or more specifically, their baseplates).
Bryan
2000 Ford E350 DRW Wagon, V10 - 400,000+ miles!
2014 CreekSide 31KQBS (QuadSlide bunkhouse)
2015 Ford Fiesta 0.999L EcoBoost
coolbreeze01
Redding, Ca
Posted: 07/11/12 01:16pm Link  |  Print  |  Notify Moderator
Of course it can be done but having towed lots of trailers, I would put both the Jeep and scoot on the same trailer, big enough for a quad or something too. Have fun.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
mowermech
Billings, MT
Posted: 07/11/12 01:49pm Link  |  Print  |  Notify Moderator
IIRC, there is only one state along the Right Coast that allows RV double towing, and New York isn't the one.
Are you sure it is legal where you live?
It is in Montana, but that is no help to you at all!
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC SWB, Cummins, 5 speed, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs and a boat.
arnoldbennigsohn
Rochester NY
Posted: 07/11/12 02:24pm Link  |  Print  |  Notify Moderator
I'm not using a ball. New York allows it only on the t-way. I know it it will not be allowed in most eastern states but I'm planing on sticking to rt 95. So I'm hoping most LEO's will just let it go.
jerem0621
Tennessee
Posted: 07/11/12 03:04pm Link  |  Print  |  Notify Moderator
Car hauler trailer may be a better option.
Tow Vehicle- 2014 Town & Country, Pentastar V6-69k miles
Pro Series 550 Round bar hitch
Draw-Tite Intella Stop Brake Controller
Fantastic Van
BarneyS
S.E. Lower Michigan
Posted: 07/11/12 06:24pm Link  |  Print  |  Notify Moderator
I am curious. How do you tow your Jeep behind the MH without using a ball hitch? Doesn't the tow bar connect to the MH via a ball, or does it have a shank that slides into the MH receiver?
Barney
Hensley "Arrow" 1400# hitch
2016 Ram Laramie 2500, 6.7L CTD, 4x4, SB
Visit our website here
 > Tadem towing
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
