RV.Net Open Roads Forum: Truck Campers: portable 12 volt air compressors
 > portable 12 volt air compressors
Page of 6
palmwhit
Arizona
Posted: 01/06/06 07:50pm Link  |  Print  |  Notify Moderator
Looking for your recommendations or experience with portable 12v compressors. I want a unit that can "air up" air bags and tires. I have a dually so I need something with a little more than the dinky hose most of these things have. This is for extended trips primarily as I have a "real" compressor in my garage. What do you guys do or use?
Regards,
palmwhit
SanCap
Sanibel Island
Posted: 01/06/06 08:01pm Link  |  Print  |  Notify Moderator
I don't use a compressor, I use a CO2 tank. It will inflate a tire in a hury, or do small jobs also. Details can be seen here. RV PowerShot
Jim
2015 Toyota Tundra, 2019 AT Summit Camper
bcs
Albany,Or,USA
Posted: 01/06/06 09:07pm Link  |  Print  |  Notify Moderator
I like my truckair and it was under $40.00. Almost anything will air up the air bags as they have very little air. The truckair will take my 245 19.5 from 60 to 110 in about 30 minutes, it does need a good 20amps however.
http://www.autobarn.net/achd-275.html
'00 ArticFox 1150, torklift
'02 F350 CC 4x4 V10 auto 3:73-LS, Firestone ride-rites, RMX monotubes, Toyo M608z 245/70R19.5
rlcorb
Central Florida
Posted: 01/06/06 09:22pm Link  |  Print  |  Notify Moderator
I use a small portable 110 volt unit I bought from Sears years ago. Have had it in three different campers and wouldn't be without one.
2006 Silverado 2500HD, 8100 Vortec, Allison 6-Speed.
2006 Durango 285RLx2 Fifth Wheel.
igboo
Sioux Falls, SD Fultimrs (WI, MI, FL, AZ, NV, CO)
Posted: 01/06/06 10:28pm Link  |  Print  |  Notify Moderator
VIAIR 200P a quality 12v compressor but costly.
You get what you pay for.
acudr
San Diego
Posted: 01/06/06 10:47pm Link  |  Print  |  Notify Moderator
got the viair 400p.... Sweeeeeet. Quiet, fast, powerful.
Bertram
sasha_j
On the Road USA
Posted: 01/06/06 11:05pm Link  |  Print  |  Notify Moderator
30 minutes each tire? Or all 4?
Our Web Site
1999 Ford F450 7.3 PSD CC 4x2, Roll-A-Long Hauler Bed, 15,000 GVWR, 26,000 GCVWR, PacBrake PBRX, AIRSAFE 25K Air hitch & KSH 80 Gal Aux Tank/Tool Box
2006 FR Sandpiper Sport F37 Toyhauler, 16K GVWR, 7K axles, 17.5" Wheels, 600W Solar
sasha_j
On the Road USA
Posted: 01/06/06 11:30pm Link  |  Print  |  Notify Moderator
Jim
Jim, at the TC vanguard, as usual. Cool solution, I must say. I like the fact that no power is needed.
How long does the tank last and how do you keep track of welding shops and fire extinguisher service shops, beverage distributors (Coke, Pepsi, Coors, etc.) and paintball supply shops for liquid CO2 refills? No problems refilling?
BradW
Mayor of Flat Rock
Posted: 01/06/06 11:33pm Link  |  Print  |  Notify Moderator
12V Compressor
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
SanCap
Sanibel Island
Posted: 01/06/06 11:50pm Link  |  Print  |  Notify Moderator
sasha_j wrote:
Jim
If I don't use the 15 pound tank to run any air tools,(I have used it to run a die grinder to cut off some rusted bolts) and just use it for tire pressures it will last a year or so to just keep the tires maintained. I haven't had to air down yet for the beach. It costs about 15 to 25$ to refill the tank at any of the places you listed. I should be able to air down to 25 psi and fill 6 tires to 90-110 Psi 3 to 6 times.
Jim
Page of 6
