RV.Net Open Roads Forum: Reese 2-1/2" Tow Beast Hitch Install on 2006 F-350
 > Reese 2-1/2" Tow Beast Hitch Install on 2006 F-350
Page of 5
BradW
Mayor of Flat Rock
Posted: 02/08/06 09:10pm Link  |  Print  |  Notify Moderator
Reese Tow Beast Receiver Hitch
Hitch data
Hitch fasteners
Instructions
Existing frame holes, 4 on each side
½” carriage bolts torqued to 70 ft-lbs
Installed hitch
1) Tools: 3/4" deep well socket & torque wrench (70 ft-lbs).
2) Removing spare makes for an easier install.
3) The easiest way I have found to install the hitch is to insert the two rear frame bolts through the frame and then lay on your back with the hitch on your chest. Lift it up against the frame while someone else starts the nuts on the two frame bolts. The two rear bolts/nuts will hold the hitch while you install the other 6 bolts/nuts/flat washers/lock washers.
Brad
downtheroad
Pacific Northwest
Posted: 02/08/06 09:21pm Link  |  Print  |  Notify Moderator
Brad,
Very nice.
Where did you get the hitch? Do they make one for an 06 GMC 2500HD? (see sig)
Thanks,
Dave
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
BradW
Mayor of Flat Rock
Posted: 02/08/06 09:26pm Link  |  Print  |  Notify Moderator
etrailer.com
I've bought stuff from them before. Very good service and delivery time, price is OK but could probably be beat.
Brad
INSAYN
NW Oregon
Posted: 02/08/06 09:30pm Link  |  Print  |  Notify Moderator
Brad when I installed my Super Hitch, I put the extension in place and that pretty much balanced the whole thing evenly when I lifted it up to the frame with a floor jack. I pressed it up there tight enough that it actually started to lift the truck a little. Loosely install all the bolts that would line up to the original holes in the frame.
Mucho easy, and easy on the back.
INSAYN
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
acudr
San Diego
Posted: 02/08/06 09:35pm Link  |  Print  |  Notify Moderator
Really good pictures.... What kind of camara did you use? They are very clear and understandable.
b
Bertram
Chino 240Z
Chino, Ca, USA
Posted: 02/08/06 09:41pm Link  |  Print  |  Notify Moderator
Nice job, info, and pics. I used the same one on my 99 1-ton dually and I don't think I had to drill any holes in the truck frame, everything bolted right up and was a nice fit. The only head-ache I have is crawling under the camper with that 48" extention, lifting and sliding it in when I tow with the camper on. It truely is a beast! But I feel secure with the whole set up.
I think I paid about about $500 includeing sales tax, from ExpressDistributing.com (shipping was cheap since they were in So. Cal.) about a year ago. I also picked up the adapter to use when I tow with out the camper & extention, it takes the 2.5" down to a 2" at the bumper.
Craig
02 Elkhorn 11X, Alum-Frame, Remote-jacks, Side entrance, Sleeps 5.
99 Chevy 3500 Crew Cab, 7.4L 4x4, Firestone Ride Rites, in cab controller & air tank, Happijac w/guides, Herculiner & Bed Mat, Pirelli Scorpians LT235/85R16 Load-E,Titan-V 2.5" w/48" ext.
BMCM
Santa Clarita, CA
Posted: 02/08/06 10:08pm Link  |  Print  |  Notify Moderator
Brad,
Why did you choose that hitch over the factory option?
Robert
F-350, Scorpion, QC, Dually/Alpenleak
All Gave Some,
Some Gave All.
WarrenS
Cypress, CA, USA
Posted: 02/08/06 10:52pm Link  |  Print  |  Notify Moderator
downtheroad: They had one for my 05 3500 last Feb. Likely the 06 is the same.
downtheroad wrote:
Brad,
Very nice.
Thanks,
Dave
Happy Trails,
- Warren
Wife, 8 year old boy, 6 year old girl
01 Lance 961 (9'6 with slide out). TorkLift Frame Moutned tie downs, FastGuns, SuperHitch
05 Chevy DRW,LB,CC,4x4,8.1L gas, Alison
78 Toyota FJ40 w/'97 350 Chevy & auto. trans.
87 Honda TRX250R
FireGuard
Ventura, Ca
Posted: 02/09/06 06:54am Link  |  Print  |  Notify Moderator
That is the cleanest underside of a truck I have seen. You should have taken it through the mud first so it would make it more fun installing the hitch.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
BradW
Mayor of Flat Rock
Posted: 02/09/06 04:37am Link  |  Print  |  Notify Moderator
BMCM wrote:
Brad,
Robert
The Ford 2-1/2" receiver hitch is not rated for use with an extension.
Brad
Page of 5
