RV.Net Open Roads Forum: Truck Campers: overloads
 > overloads
the trippers
Utah
Posted: 03/04/06 09:37pm Link  |  Print  |  Notify Moderator
Hi,
I have a question, does anybody use Timbrens on their truck as overloads? If so, could you tell me how well they work.
Steve
2018 Tiffin Allegro 32SA
HoodCanalNorth
Brinnon,Wa.
Posted: 03/04/06 10:48pm Link  |  Print  |  Notify Moderator
Just installed and used for the first time. Seem to work real well. Got them on line from a place called "Anything truck". $150.00 and they paided the shipping.
TCing since 1970. 1997 Ford F150 SC 4x4. 2004 Lance 815. E range tires,Rancho 9000 shocks,Timbren overloads.
Guffster
Wedowee, AL
Posted: 03/05/06 02:13am Link  |  Print  |  Notify Moderator
the trippers wrote:
Hi,
Steve
I use them on the rear only of my F-350. Mainly, to level the truck after loading the camper. They work great and are pretty easy to install once you are able to remove your original bump stops.
The ride of the truck unloaded is generally the same as before, however when you hit a speed bump you can feel a solid thump where they hit.
I am very happy with them.
2002 Ford F-350 PSD 7.3L SRW 4WD CC LB
1993 Lance 880
Torklifts, Timbrens, Hellwig Rear Swaybar, Rancho 9000's, Interstate House Battery. IntelliPower PD9245C (built-in Charge Wizard) Converter. Kipor Sinemaster 3000TI.
See our website for more
Ibeme
Surrey, B.C., Canada
Posted: 03/05/06 07:31am Link  |  Print  |  Notify Moderator
What Guffster said about speed bumps. We are happy with our Timbrens. On our truck it was undo one nut, take off bumpstop, replace with Timbren and tighten nut. Repeat for other side. Your mileage may vary.
merlin
Merlin, Dianne & Chimo
2001 F150 SCSB 4x4 etc.
Palomino 1250SB
Islander, Concours
monkey44
Cape Cod, MA and Central Fla
Posted: 03/05/06 09:29am Link  |  Print  |  Notify Moderator
Put them on both my trucks to limit sag when the campers is loaded. Also, helps limit sway when off-roading. I'd do it again in a hot minute. Much better than air-bags with the maintenance and adjustments, but serve a slightly different purpose. They work very well. Same as stock ride when unloaded, but I agree with above posters -- a stiff "bump" if you hit large potholes, but not enough to make me use anything else.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
the trippers
Utah
Posted: 03/05/06 09:51am Link  |  Print  |  Notify Moderator
Do they work as well as airbags? Should I add a sway bar as well as the timbrens? I am looking for less sway and roll. they wife won't drive it right now! She is worried about it tipping over![emoticon]
Steve
Berticus
Boise, ID
Posted: 03/05/06 10:43am Link  |  Print  |  Notify Moderator
I installed mine when I got my 'new to me' 2000 f350. Same as above in all and in regards to your referance to sway bar; I do know that when I added the timbrens I saw a huge diffence in sway control. Now my f350 came with the stock sway bar in the rear. I am surprised that your HD 3/4 does not include a rear sway bar. But you can try the timrens 1st and see if they are good for your setup & sway. If not they add the sway bar later. Just my opinion.
The Setup:
96' Serro Scotty 25'Dodge,4x4,Diesel,Class-C, 86 20' Chris Craft LTD.
HoodCanalNorth
Brinnon,Wa.
Posted: 03/05/06 11:53am Link  |  Print  |  Notify Moderator
Rancho 9000's got rid of most of my sway. Also load range E tires got rid of sidewall flex. DW is now willing to try driving and I'm willing to let her!
monkey44
Posted: 03/05/06 11:55am Link  |  Print  |  Notify Moderator
QUOTE: But you can try the timrens 1st and see if they are good for your setup & sway. If not they add the sway bar later. Just my opinion."
I agree. Check first and add a sway bar if you sitll get sway. I had Timbrens first on my 1500 GMC, but still got sway and a little sag, but Timbrens helped alot. With my 2500 GMC, very little sway, rights itself quickly, and virtually no sag. Timbrens engage at one inch, and and my rear end drops about an inch and a half loaded -- camper weighs 2190 wet and loaded.
3+tons ain't pc
northern, ca.
Posted: 03/05/06 12:37pm Link  |  Print  |  Notify Moderator
Timbrens are well worth their cost. Mine work great and I would easily choose to go this route having to do it again. They also greatly reduce sway. However, the first set that the dealer installed caused my truck to ride stiff when EMPTY, but otherwise excellent overall when loaded-up with the TC. I called trucksprings.com and found that the dealer had installed the wrong set (insufficient clearances). You need to have 3/4" to 1" clearance between the axle and timbren when unloaded for them to work properly. Once having installed the correct set, no more stiff ride problems (over stock 2500HD)! They work exactly as advertised. No need for any other co$tly upgrades. No morning after sickness!
2007 Dodge 3500 DRW,4x4,L/bed,Q/cab,6.7 diesel w/exhst brake,6 spd. auto,4:10,Timbrens, 2005 Citation 9-6 T/C, 1 keeper wife,1 son, 1 yellow lab, 2 quad polaris atv's & trailer,extreme lust for freedom & self accountibility, neither low output or income.
 > overloads
