RV.Net Open Roads Forum: Truck Campers: Rays Popup Projects: Electrical System
 > Rays Popup Projects: Electrical System
rlchenry
Wake Forest, NC
Posted: 03/05/06 03:44pm Link  |  Print  |  Notify Moderator
Still working!!!!
Here are some things I put in for a better electrical system.
Here is a shot of the whole thing. I plan to put two (if I can fit) golf cart AGM's in here, otherwise one large 12V AGM. I need the AGM because I don't want to vent this compartment and it is inside the camper. The little battery is what came with the camper. I am careful with it for now (flooded type).
I put in a Blue Sea combiner that is linked to the truck's battery. Some new bus bars (to an additional DC panel) and fuses are below it.
This is the new DC panel that I wanted some switched items for (stereo). It also conveniently has a DC voltmeter to check the battery level. I guess I need some new labels, huh?
Right next to the battery, and before power goes to ANYTHING else, I put an emergency shutoff switch and a big honkin' fuse. This also gives me a way to COMPLETELY shut off any loads on the battery for working on the system, etc.
And finally, just for grins, I put a cheezy automotive type ammeter in line with the battery. This lets me see (in VERY rough terms) how much current is going into (charger working?) or out of (left someting on?) the battery.
Sunlite Eagle SB
'04 Silverado 2500HD Duramax 4x4
Ray's Truck Camper Page
kottfam6wi
South Central Wisconsin
Posted: 03/05/06 04:39pm Link  |  Print  |  Notify Moderator
Be careful, as even sealed batteries can give off small amounts of gas while charging.
Joe
Our Family Pictures
Joe & Erika
Chris-16, Emily-12, Jessica-10, Jason-9, Derek-4
"Rallies Attended 19 1/2" (Wahoo!! we're catching up!)
2005 Dodge Ram 2500 Quad Cab 5.9L CTD
2005 K-Z Durango 315BH 5th Wheel (2nd Camper)
rlchenry
Wake Forest, NC
Posted: 03/05/06 05:18pm Link  |  Print  |  Notify Moderator
Thanks for the warning!
I don't think I'll ever be putting enough amps into it for that to be a problem, though - my charging systems are pretty tame.
AGMs would take quite a lot of charge current before they would start gassing at all.
kottfam6wi
Posted: 03/05/06 05:43pm Link  |  Print  |  Notify Moderator
You are correct, but some people think AGM's are completely immune from gassing.
