RV.Net Open Roads Forum: Truck Campers: Need to buy an air conditioner
 > Need to buy an air conditioner
Windwalker55
Missouri
Posted: 01/20/07 07:12am Link  |  Print  |  Notify Moderator
Okay you all, I need to buy an air conditioner. Went to Alaska last summer and didn't need one, but will be in hot, humid southern Missouri this summer.
I would assume that the smallest of units would suffice for a truck camper. Do any of you have suggestions on makes or models? Or even better do any of you advise against a certain make or model?
Thanks for your help.
Larry
2007 Kodiak 160 Hybrid
"The mountains are calling and I must go." John Muir
My Blog
FredAr
Arizona
Posted: 01/20/07 07:20am Link  |  Print  |  Notify Moderator
What size of generator do you have, as to wattage?
In TCs a lot ~smaller~ A/Cs would suffice than what oftentimes is installed in them, allowing you to use a smaller generator, or to use less gas. Or even a portable one (i.e. H2000). Polar Cub is the smallest (7.7k BTU).
2006 Dodge RAM 2500 Mega Cab
2007 TC (Pastime 880ST) / 2005 TT (Montana 335 RLBS)
Itchey Feet
Wyoming
Posted: 01/20/07 07:30am Link  |  Print  |  Notify Moderator
I have a Summerwind 8.5. Installed a Polar Cub, It has run in 100+ temps and kept the camper plenty cool. It is the 7.7 -----
My feet are fine as long as they are traveling.
Windwalker55
Missouri
Posted: 01/20/07 07:32am Link  |  Print  |  Notify Moderator
I have a Honda EU2000i generator. Good question.
F350OilBurner
Central MA
Posted: 01/20/07 07:51am Link  |  Print  |  Notify Moderator
All Coleman Polar Cubs are now 9200 btu's. It a great unit and will run on the Honda 2000 in Eco mode with no problem at all. You'll get 6-7 hours run time in 90+ degree heat.
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
frenchyd
Lake Havasu City, Arizona
Posted: 01/20/07 08:20am Link  |  Print  |  Notify Moderator
I have a dometic duo-therm briskair 7,000, works great with my 2000.[emoticon]
00 F250 SD PSD, Super Chips, CC SB 4X4, Camper/Trailer pkg, sway bars front/rear, Timbrens, Rancho shocks. Big Foot A/T LT265/75R16E, Rims 16X7 Alum. Torklifts, fastguns, 05 Sun-Lite 865 WS SB, Fiberglass, Ext. Cabover. Titan Remote Jacks, 2128 dry WT.
FredAr
Arizona
Posted: 01/20/07 07:42am Link  |  Print  |  Notify Moderator
Polar Cub 7.7 I would suggest, allowing you plenty of power for other things without having to shut things on and off. Besides it oftentimes allows you to stay on 'Eco' when only the little Cub is running, depending on altitude. The best of luck.
/I wish I had a Polar Cub and not this 13.5kBTU monstrosity that came with mine.[emoticon]
FredAr
Arizona
Posted: 01/20/07 08:50am Link  |  Print  |  Notify Moderator
^^^ Good point Brad, just the noise level of some of those bigger A/Cs, never mind the noise of the generators (and in what mode) to run them, is another important consideration. Anyone have DB noise level figures on A/Cs, be enlightening to know them.
Just came from a trip with 4 other TC friends, we ended up running my H2000 parked well away from the units, but we all piled into my friend's Lance for evening dinners with the smaller and very quiet A/C. Besides he happened to be the best cook. [emoticon]
BradW
Mayor of Flat Rock
Posted: 01/20/07 07:49am Link  |  Print  |  Notify Moderator
Ditto.
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
BradW
Mayor of Flat Rock
Posted: 01/20/07 08:24am Link  |  Print  |  Notify Moderator
That sound like another option.
How loud is your unit? I'm asking because our 11,500 Btu/hr unit is very loud on the inside of the camper.
Next time, I want a quieter and lower capacity a/c unit.
Brad
