RV.Net Open Roads Forum: how much pressure do run in your airbags?
 > how much pressure do run in your airbags?
tri5ron
Orange County Ca. USA
Posted: 02/03/07 05:08pm Link  |  Print  |  Notify Moderator
just wondering,...
I dont have the onboard compressor installed yet, so pressure at different loads is a p.i.t.b., but it seems to feel right at about 24-27 psi. funny part is, the bags dont start to move until 40 psi.
So what psi do you run in yours?
Do you have a onboard compressor?
Do you adjust it while in route?
trailer, no trailer? etc, etc,...
Happy trails,
Ron
P.S.- If you smell wood burning, or see smoke,
don't worry, It's just me trying to think
97 Chevy Suburban towing a...
14' huntin' Toybox,
Junket
Klamath Falls Or.
Posted: 02/03/07 05:31pm Link  |  Print  |  Notify Moderator
Camper off 5-7#
With camper bump stops on overloads touching
No on board air
Leave it alone once I set it
Ken
2005 Dodge Cummins 610 325Hp 3.73 Auto
2016 Wildcat 26FBS
Go Fast 66 Cobra replica 500+HP Richmond 6sp
2015 Jeep unlimited
23ft. Striper boat
hotvet67
michigan
Posted: 02/03/07 05:50pm Link  |  Print  |  Notify Moderator
tri5 - With out TC 5psi , when TC is loaded it squeze's to 20psi + Then I lower to 5psi for driving with camper on , any more than 10psi and I get sway.
I use a air tank to fill , works good to level at campsites.
2004 Lance 845
2006 F350 PSD 4X4 SWB 20" Fact. Wheels
1967 corvette drag car
Aktravler
Valdez, Alaska
Posted: 02/03/07 05:59pm Link  |  Print  |  Notify Moderator
I have the Firestone Ride Rites with the on-board compressor and tank. I run at the minimum of 5 pounds when empty, and usually at 45-60 depending on road conditions and my rigs load at that particular time.
I do tweak the pressure on the fly for road conditions. Not much difference when I am towing the boat, especially since we put a dual axle trailer under it.
Surfing on Hughes.net/Sprint Aircard
Mine-'02 Ram 3500, CTD DRW
S&S Avalanche 11DBS-Torklift TD's,SH & FG's
His-'03 F350 PSD SRW & Raptor 3612DS TH
Air Hitch -Edge Juice w/Attitude
Gas & Gumption!!!
26' Alweld, 200hp jet & prop
TumbleweedKen
Lake Ouachita, AR , Ouachita National Forest
Posted: 02/03/07 06:00pm Link  |  Print  |  Notify Moderator
5-10 psi empty, the maximum 100psi when loaded, just sitting on the bottom overload and about an inch or so lower than the factory delivered suspension height, no adj. when loaded
2001 Ram 3500 DRW SLT Quad Cab
Cummins, 4x2 Auto, 3:55s LSD
K+N Air, 5000# Air Lifts, Rancho
9000s, Camper/Tow Packages, Linex
Liner, Dark Garnet Red
2001 Lance 1121 Truck Camper
4600# Wet and ready to go
My Truck Camper Travel Photos
280fx
McDonough, Ga, USA
Posted: 02/03/07 06:09pm Link  |  Print  |  Notify Moderator
10 psi empty, 60 psi loaded.
Dean and Liliana
2008 Ford F-450 Lariat Super Duty 6.4 Powerstroke
2009 Host Everest Triple Slide
BobTowne
Fairfield, CA, USA
Posted: 02/05/07 09:17am Link  |  Print  |  Notify Moderator
About 5 psi empty, ~80 psi loaded.
GreatWhite
2004 Dodge Ram 3500 Quadcab Dually
2004 Alpenlite Santa Fe 1150
BSH38
Rochester, NH
Posted: 02/05/07 09:46am Link  |  Print  |  Notify Moderator
I had my truck aligned with the camper on by a garage that specializes in servicing big trucker, buses, etc. They told me to make sure the truc k is level & seeing I have a large slideout on my Arctic Fox, I was told to go with 80psi on the slide out side & 60 psi on the other. That's what I go with.
2000 Ford F-350 4X2, DRW, CC, 7.3 PSD, 3.73:1 Rear, Firestone Air Bags, Rancho RS9000X shocks
2006 ARCTIC FOX (Silver Fox) 1140 Dry Bath, custom built, loaded
Me (Retired), wife Cathy & Pokey - who really is a Poodle although he thinks otherwise.
scottz
Big Lake, MN
Posted: 02/05/07 10:23am Link  |  Print  |  Notify Moderator
65psi loaded
25psi unloaded
I do not use an onboard compressor
I will remove air after I remove camper from truck
I do haul a trailer with and without the camper however I do not adjust the airbag setup
2004 Silverado 2500HD,LB,Gas,4x4,Air-Bags, Rancho 9000X/XL, Michelin LTX MS2 265/75-16
2005 Lance1030, Lifeline AGM Batteries, Yamaha EF2400iS Generator
2006 Tritontrailer ATV168 4pl, and ATVs
TumbleweedKen
Posted: 02/05/07 10:45am Link  |  Print  |  Notify Moderator
I have been wondering if it was possible to have this done.
Sounds first class to me.
