RV.Net Open Roads Forum: Truck Campers: Rancho Shock owners should read this
 > Rancho Shock owners should read this
littlebigbar
Victoria, BC, Canada
Posted: 05/14/07 02:27pm Link  |  Print  |  Notify Moderator
I went ahead and attempted to repair the manual adjustment knobs on my RS9000X Rancho adjustable shocks. Several forum members were kind enough to reply to me earlier topic HERE.
To my disappointment, the two rear shock adjustment capabilities are seized. The adjustment knob is not water tight and has allowed water to enter the mechanism and both are severely corroded.
Despite that fact that one knob could be moved from #1 setting to #8 setting (and the other only went to #6 setting) the shocks are corroded on a high setting, (which I suppose is good news). When I removed the knobs, it was clear that the internal adjustment piston has siezed. However, the knobs still turn which have made me think that I was actually adjusting them.
I'll have to admit that I have noticed a stiffer ride in the last month since the camper has been off the truck, so I should have assumed something was wrong.
I removed and inspected the knobs on all four shocks. The rear ones are both shot, but the front ones are still operational... I think I caught them just in time and have cleaned them out.
Here are the photos:
1. Kinda rusty down there.
2. Corrosion on worst shock. Piston is stuck in place.
3. Second bad shock, even after cleaning etc. the piston is shot.
So, I would suggest others who own Ranchos may not be aware that their shocks are not functioning in the correct manner. Perhaps maintainance proceedures on the adjustment knobs might include:
1. Silicone the screws and the gasket when first installed to make future removal easier. I had a heck of a time cleaning the screws to allow the allen key to fit, for removal.
2. Come up with some way to avoid water, road salt, grime, etc from coming into contact with adjustment knob.
3. Annual or semi-annual removal of rear knobs to inspect, clean, and ensure water tightness.
Now it's off to the Rancho website again to pursue warranty replacement, albiet I will have to likely pay to have the shocks re-installed (if replaced).
'01 F350, SRW, CC, 4x4 longbox
Rancho 9000x, Firestone Ride-Rites, factory swaybars
'04 Bigfoot 9.6 and '96 Coleman Cheyenne (popup)
looney bin
Nevada City, CA
Posted: 05/14/07 02:32pm Link  |  Print  |  Notify Moderator
good to know...thanks
looney bin
blipblip
round mtn
Posted: 05/14/07 02:56pm Link  |  Print  |  Notify Moderator
Good information, thank you.
BradW
Mayor of Flat Rock
Posted: 05/14/07 03:12pm Link  |  Print  |  Notify Moderator
I had two 9000's do the same thing on our 1996 F-250.
Keep us posted on whether Rancho will replace them under warranty.
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
littlebigbar
Posted: 05/14/07 02:46pm Link  |  Print  |  Notify Moderator
These shocks are less than 3 years old. And the truck only sees less than 10,000 miles per year on the road. I wash the truck off after every trip and make sure to rinse off the shocks.
The roads here are salted when there is ice/snow, but in the last 3 winters I'll bet the truck has only seen 10 days on the road in such conditions. I was amazed at how fast the shocks rusted. [emoticon]
* This post was edited 05/14/07 03:00pm by littlebigbar *
F350OilBurner
Central MA
Posted: 05/14/07 02:35pm Link  |  Print  |  Notify Moderator
How old are those Ranchos? They look like the shocks on the Titanic. That's one thing I never liked about Ranchos, they rust real bad, real fast. [emoticon]
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
fast.5
Ontario, Canada
Posted: 05/14/07 03:43pm Link  |  Print  |  Notify Moderator
Hi: They just replaced mine for the same reason. Having to replace them is just a PIA, so I took my new ones apart and filled the void with fluid film. Don't know if this will extend there life but it can't hurt..
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
trapperdick
Bridgton,Me.
Posted: 05/14/07 04:56pm Link  |  Print  |  Notify Moderator
I wonder if it would help to smear them with grease every once in a while.......TD
OLDER AND BOLDER,,,,,N1ATF
Ford F-350 Dually Diesel, Lance 9SC, Harley Davidson Heritage Softail, 12 ft Hallmark trailer and Skeeter the camping beagle ">.........
joec
Salem and Lakeview Oregon
Posted: 05/14/07 04:44pm Link  |  Print  |  Notify Moderator
Good info to know, thanks for passing this on! We seem to have lots of water here in Oregon. Need to put this on my to-do list [emoticon]
2006 F-350 PSD DRW - 2004 Eagle Cap 950 - Rancho 9000s - Ride Rites and "> "Homemade Super Bump Stops" ">
t/c hobo
RHODE ISLAND
Posted: 05/14/07 06:21pm Link  |  Print  |  Notify Moderator
well now what i need to replace my rancho shocks that were
stock in my 2004 f 350 ford i have 72000 miles on
truck i have been waiting for the new 9000XL come out
this month should i look for some other make
