RV.Net Open Roads Forum: Truck Campers: Tight fit on Lance
 > Tight fit on Lance
dandba
Denver, CO
Posted: 04/16/08 10:00am Link  |  Print  |  Notify Moderator
After loading the camper on the truck for the first time, I'm encountering a real pain for alignment.
This is hard to explain, so bear with me. The truck box has the Happijac cross member bar with the tiedowns sticking out the sides. When I load the camper on to the truck (rubber bumper touching the box), the front jacks of the Lance stop almost dead center on the tiedown brackets that stick out. This isn't too bad except the tabs stick out to the point where I have about 1/8 to 1/4 inch room on either side without them hitting the jack.
I realize this is just due to the width of the camper vs. the width of the truck and there's really nothing I can do about it.
Right now the driver's side is only slightly touching the jack needs to be adjusted. Can I just move forward that 1/32nd of an inch forward just so it's not touching, and therefore the rubber stops are no longer touching the box? My understanding is that it is very important to have them touching.
If so, I'll just drop the jacks and wiggle the truck like a worm to gain that extra room without having to completely starting over loading.
2002 F250 4X4 Crew Cab
2002 Lance 815
2001 Crestliner Fish Hawk 1650
EricCO
Colorado
Posted: 04/16/08 10:17am Link  |  Print  |  Notify Moderator
I haven't had any problems when my bumpers aren't all the way forward touching the front of the bed.
2002 Ford F-350 CC LB PSD
2007 Travel Lite 960rx Ultra
2009 Lund 208 Pro-V GL with 250 hp Verado
BradW
Mayor of Flat Rock
Posted: 04/16/08 10:32am Link  |  Print  |  Notify Moderator
I'm wondering if the tie-down brackets were installed incorrectly on the front of the bed? How much do they stick out on each side?
One option might be to install the swing out jack brackets required on duallys.
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
dandba
Denver, CO
Posted: 04/16/08 10:56am Link  |  Print  |  Notify Moderator
Good question Brad. I'll take a pic and post it.
jmtandem
western nevada
Posted: 04/16/08 11:06am Link  |  Print  |  Notify Moderator
TorkLift tie downs will fix this problem in the front.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
BradW
Mayor of Flat Rock
Posted: 04/16/08 11:15am Link  |  Print  |  Notify Moderator
I think my brackets only stick out about 4" on each side.
bilmarde
MICHIGAN
Posted: 04/16/08 12:46pm Link  |  Print  |  Notify Moderator
If you are worried about the bumpers touching the front of the bed you can get a piece of 4x4 and wrap some carpet around it a few times. That should make it larger than the bumpers. Just set it in the bed and snug the camper against it. Cheap and easy.
Bill D
2011 Ford F250
1998 Cari-Lite 31RK
1990 Chevrolet 3500 Dually
1995 Lance 945
Crumm
Fairbanks Alaska
Posted: 04/16/08 01:31pm Link  |  Print  |  Notify Moderator
I would go with a 2"x4" to keep the camper as far forward as possible yet clear the jacks. It is best if the camper bumpers are touching in the front as in a panic stop it will be touching even if it doesn't start out that way.
2015 F350 SuperDuty, SC, LB Torklift hitch and tie-downs, LT285/75R18 Toyo AT II 4080@80psi
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS
readytow
Washington
Posted: 04/16/08 01:33pm Link  |  Print  |  Notify Moderator
What the last guy said.[emoticon] But seriously, I had that problem on a different truck and camper, and I just put a piece of 2x6, the length of the happi jac cross bar, to set the camper back a bit, and it worked fine. Or, you can change your rubber bumpers to a different sized ones, to get the same affect.
mike9121
Deep in the Heart Of Texas
Posted: 04/16/08 02:05pm Link  |  Print  |  Notify Moderator
I have the same problem with mine as well. Both front jacks are more than a little scratched up. I never thought about adding something in the front of the bed. Seems like a good idea. Now for all the COG gurus out there. How much would moving the camper back, say for example 1 inch, mess with the COG?
2007 F250 Lariat 4WD PSD 6.0 W/ Timbrens /Rancho RS9000
2007 Lance 815 (Not with all the options but getting there. Added DVD/Stereo, 24" WS HD Flat panel, HD DTV, 500W Inverter, Fantastic Fan, Short bed kit, Jack Plates and Atwood Wireless Power Jacks)
