RV.Net Open Roads Forum: Truck Campers: Truck Camper slides around
 > Truck Camper slides around
ReadyToGo
Minnesota
Posted: 10/29/09 02:30pm Link  |  Print  |  Notify Moderator
My TC slides sideways on the truck. There is less than 1/2 inch on each side by the wheel well. I have two small locked doors on the backend. I can see where one of them is almost touching the edge of the truck. I have had to move the camper over twice now. fortunately it only needs to move about 1/4 inch and then the door clears.
I also have to let you know that the camper sites on top of some 2/4 to raise it over the 5th wheel base hitch. I have the Happy Jac tie downs and have read and reread the instructions on how tight to put the tiedowns and follow that religiously.
1. Do all slide in campers slide a little bit side to side?
2. Does this happen because it is sitting on the raised platform?
3. Should I forget about it and not back the camper all the way up to the cab? That way the doors would jam against the truck.
sleepy
Oak Ridge,Tennessee
Posted: 10/29/09 02:40pm Link  |  Print  |  Notify Moderator
I like the KISS principal...
I cut 4 pieces of 2X6 lumber that fit the space on each side... front and back. I put them in when I load the camper... it may slide a 1/4" then the board stops it.
I've been doing it that way for close to 40 years.
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
Artum Snowbird
Campbell River, B.C., Canada
Posted: 10/29/09 02:45pm Link  |  Print  |  Notify Moderator
What you should do would be to put some pieces of wood into your box that allow you to clear the fifth wheel hitch, but also have stops to prevent sideways sliding. The camper will fit into slots and your two by fours or wider pieces will run from side to side, just fitting between the side walls.
The camper will then fit into pieces screwed to the sideways pieces. As you lower the camper into the box, it helps if the wedging pices are tapered so the camper will slide down into the perfect place.
Adding another piece across the very front would prevent the camper from slipping forward just off the doors.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
MTW1
north carolina
Posted: 10/29/09 03:12pm Link  |  Print  |  Notify Moderator
Loose the bedliner - IF you have one, then add a rubber mat, should do the trick
EricCO
Colorado
Posted: 10/29/09 05:01pm Link  |  Print  |  Notify Moderator
Can you secure the 2x4 platform to the camper? Maybe the camper is sliding on the 2x4's? My 2x4 riser for cab clearance is secured to the bottom of the camper and it's sitting on the line-x spray on liner and it doesn't move.
2002 Ford F-350 CC LB PSD
2007 Travel Lite 960rx Ultra
2009 Lund 208 Pro-V GL with 250 hp Verado
ReadyToGo
Minnesota
Posted: 10/29/09 05:23pm Link  |  Print  |  Notify Moderator
Thank you all. I think the Foam, or the Traction Strips might be the answer.
I will also look at the possibility of anchoring the boards down.
It will just depend on which way I get to first.
NRALIFR
Truck Camping Out West
Posted: 10/29/09 05:44pm Link  |  Print  |  Notify Moderator
I've got 5th wheel hitch rails in my bed too.
So I did this to the bottom of my camper.
The boards on the bottom not only allow clearance for the rails, two of them are positioned to land right in front of the two rails, and prevent the camper from sliding to the rear. The boards on the front of the camper and the truck bed keep the camper from sliding forward. The boards on the sides of the tub keep the camper centered between the wheel wells. Since I've done this, the camper no longer moves while we are on a trip.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
ramn4ver
Richland,WA
Posted: 10/29/09 03:51pm Link  |  Print  |  Notify Moderator
I use a rubber bed mat. No sliding around.
His 2004 Dodge 3500 4x4 CTD 6 spd
Her 1998 Dodge 3500 4x4 CTD 5 spd
2013 Rushmore Jefferson
Our Home
NWBombers,diesel trucks forum
bldrbuck
one or the other
Posted: 10/29/09 03:53pm Link  |  Print  |  Notify Moderator
Many people use a piece of foam in the bed of the truck to raise the camper. I would take that approach and cut out for the 5er hitch parts. I cut my rubber mat to fit over the 5er rails and it worked fine with foam.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
dmax lover
Portland,Oregon, USA
Posted: 10/29/09 04:47pm Link  |  Print  |  Notify Moderator
I had a rubber mat only and it would still slide slightly in the bed - I added 3m traction strips on the bed floor and it solved that issue.
I glued grey indoor/outdoor carpet to the rear tailgate opening to make sure that if it did slide over and make contact that no damage would occur (my camper is fiberglass...)
jeff
2005 Chevrolet Duramax 3500 SRW Crewcab Longbed (KYB Monomax Shocks, Michelins,Hellwig Rear Swaybar)
2006 Northern Lite 9.6 Classic (Torklifts & fastguns)
Northern Lite Owners Club
