RV.Net Open Roads Forum: Tech Issues: Door lock is stuck
 > Door lock is stuck
mtchp1
Mountain City, Texas
Posted: 03/11/10 08:21am Link  |  Print  |  Notify Moderator
The door lock is siezes up and in the locked position. I haved tried crawling in throgh the back hatch and removin the lock but it is fastened with a screw from the bolt edge of the door. Any suggestions anyone? I do not want to call a locksmith and the camper is out of warranty.
Mitch
jauguston
Bellingham, WA
Posted: 03/11/10 08:37am Link  |  Print  |  Notify Moderator
If it is the typical Tri-Mark door latch that many RV's use often the tang on the back of the latch bolt breaks off. About the only way to get it open is to drill holes from the outside until you can get at the latch spring-pull it out then drill a shallow hole in the back end of the bolt so you can stick some kind of pry into the bolt and pry it out of the door jamb. It is a common failure and regularly stocked by most good RV repair shops in both black and white. Been there--done that.
I drilled a series of holes in the cast aluminum in a circle and broke the center of the circle out. Did it in a State Park.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
pulsar
Lewisville, NC
Posted: 03/11/10 12:33pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
Wherever I happen to park
Posted: 03/12/10 10:01am Link  |  Print  |  Notify Moderator
On mine I had to use a special "Pick" tool (This is actually designed for removing oil seals not picking locks) the one I used is like an ice pick (hence the PICK name) but the end is "L" shaped.. Actually any L-shaped tool would work
I was able to sneak it into the striker plate area and depress the plunger
Then I removed the striker bold and locked the door with the deadbolt till I was able to get a new 100 dollar Tri-Mark hunk of junk
I don't think much of Tri-mark locks in case you ahve not guessed.. The bolts are very cheaply made, better metal would be.. Way better.
Home is where I park it.
SAR Tracker
Central Oregon
Posted: 03/11/10 08:57am Link  |  Print  |  Notify Moderator
Might be a good weekend project of "preventive" maintenance... just remove the old one and stick in a new one. Assuming the new one is of better quality than the original?
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
BB_TX
McKinney, Texas
Posted: 03/11/10 09:00am Link  |  Print  |  Notify Moderator
Similar thing on my 5th wheel. We have a laundry chute in the floor over the basement. Crawled thru the basement and up the chute to get inside. Took the inside plate off the lock set and managed to get the bolt to slide back with a screw driver. Loose screws had allowed the tang on the lock/unlock lever to come out of the bolt mechanism. Lubed it, put it all back together, and has worked fine ever since.
Reminds me that I need to check those screws again to make sure they have not come loose again.
