RV.Net Open Roads Forum: Truck Campers: polar cub 9200 and honda 2000W
 > polar cub 9200 and honda 2000W
Adacas
Abbotsford BC
Posted: 06/23/10 04:36pm Link  |  Print  |  Notify Moderator
Greetings RV friends. From a rather long hiatus I have returned to the forum with the following questions, re AC and gen sets. It seems I had researched this before with answers, but a search brings back none of my old posts on this topic.
I want to put the polar cub 9201 on my AF 990 and run it with the Honda 2000W gen. I'm sure I'd figured this before to work together, but I go to order the ac unit at my local RV World and they're telling me no way it will work. Apparently this unit needs 2500W minimum to start.
Are there any folks here using this pair and find its working? Apparently this 9201 is the high efficiency unit that has replaced the 9200 BTU unit and this maybe where my problem lies. I'm trying to stay with a lower BTU unit so I can run it on a small generator that will fit in my compartment.
My apologies if this has been discussed at length before.
TIA
'05 F350 6.0L PSD DRW 4x4 LB CC
'06 AF 990
Clattertruck
Centennial Colorado
Posted: 06/23/10 04:49pm Link  |  Print  |  Notify Moderator
I have a Polar Cub 9000 in my Snowreiver 10.8. My Honda 2000 runs it fine up to 9000ft (2743m).
Clattertruck
2008 SD F450 Pickup PSD 6.4L CC 4X4 DRW, Lariat Auto trans 4.30 LS, 2013 Lance TT 1885, Toyota 2014 Tundra Crew Max 5.7.
FF1063
NY
Posted: 06/23/10 05:55pm Link  |  Print  |  Notify Moderator
* This post was edited 07/13/10 07:20pm by FF1063 *
gerrym51
unknown
Posted: 06/23/10 08:06pm Link  |  Print  |  Notify Moderator
this will definitely work. east end campers uses this combo a lot.
Just remember- a refrigerator on automatic will use electricity(120volt) as first option. so make sure on propane. secondly the aformentioned battery charger. might have to switch charger function off.
BradW
Mayor of Flat Rock
Posted: 06/24/10 04:37am Link  |  Print  |  Notify Moderator
Good question. I would like to hear from someone who has that particular model number (9201 not 9200) and is running it on an EU2000i.
Brad
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
FF1063
NY
Posted: 06/24/10 10:47am Link  |  Print  |  Notify Moderator
J&S~B
Oceanside, CA
Posted: 06/24/10 12:48pm Link  |  Print  |  Notify Moderator
There are two current 9201 models listed on the manufacturers web site--Model "B" and "D" and both are rated 9200 btu cooling. Amp and watt slightly different.
I have a 9201D and I have run it up to 7000 feet with the Honda 2000 without any modifications. Have not needed it for higher elevations, yet.
Maybe this will help
Series B
Series D
GMC Sierra 2500 HD 4X4; Lance 815;
Adacas
Abbotsford BC
Posted: 06/24/10 01:32pm Link  |  Print  |  Notify Moderator
Thank you all for your input. The yes crowd prevails, at least on the older model 9200, however with the 9201 a successful match-up remains to be seen. I have ordered the unit anyway and will take a chance to see if the Honda 2000W gen will be man enough. I will report my findings soon as I know, prob within a week. Of course I welcome any additional input from you all as it comes.
Snow River TC
BC Canada summer / Jalisco, Mexico winter
Posted: 06/24/10 03:27pm Link  |  Print  |  Notify Moderator
I have a 9201B which is is 9200 BTU, the 9201A is only 8300 BTU. The 9201 B runs just fine off my Honda 2000. I have also put a switch in to stop charging via my converter if I wish. I had to do this to allow my microwave to run off the Honda. I do nto seems to need to do it with the A/C.
Here are the spec sheets for both:
9201-B
9201-A
9001
* This post was edited 06/24/10 03:34pm by Snow River TC *
Adacas
Abbotsford BC
Posted: 06/24/10 03:47pm Link  |  Print  |  Notify Moderator
Noted, and thanks. With that I have ordered the unit and will hope for the best, not sure which unit I will be getting, of the two you mentioned.
