RV.Net Open Roads Forum: Full-time RVing: I have a stupid? question
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > I have a stupid? question
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/29/12 12:33pm Link  |  Print  |  Notify Moderator
I agree with the above posts but for not much money you can add one of these. Not sure if this is my my tank level sensor works so well.
04 Monaco Dynasty 42' quad slide
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
Leadfoot41
BAYSE VIRGINIA
Posted: 07/29/12 01:36pm Link  |  Print  |  Notify Moderator
I remember yrs ago it was recommended that only 1-ply TP was being used but of course since then things have & do change. Enjoy.
leadfoot41
Dutch_12078
Seeing North America with all the comforts of home
Posted: 07/29/12 01:43pm Link  |  Print  |  Notify Moderator
To be specific, we've used Charmin Ultra Soft in our RV's for years without any problems. It does pass the "water test", and even though it takes a bit longer than some others to break down, it's still faster than I can pull up my britches and run outside to dump the tank, so no worries... [emoticon]
Dutch
2001 GBM Landau 34' Class A
W4RLR
Sewanee, Tennessee
Posted: 07/29/12 05:16pm Link  |  Print  |  Notify Moderator
I call RV TP "John Wayne" toilet paper. Why? Because it's rough, it's tough, and does not take******off of ANYONE! :-)
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2008 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?"
Tom Clancy
ken white
Ohio
Posted: 07/29/12 05:23pm Link  |  Print  |  Notify Moderator
Angel Soft dissolves well in the tank but stays together when needed...
[emoticon]
2014 RAM C&C 3500, 4x4, Club Cab, Hauler Bed, DRW, Aisin, 3.73's, etc...
2013 DRV Tradition 360 RSS
LED Lighting
570W of ET Solar Panels
MorningStar MPPT 45
Wagan 1000W Elite Pro Inverter
Duracell EGC2 Batteries with 460 A-H Capacity
jackandh2o
Golden Valley, Arizona
Posted: 07/29/12 08:35pm Link  |  Print  |  Notify Moderator
We also use Angel Soft. 4 years in the fifth wheel and 6 years in the septic system at the house. Had no problems whatsoever.
Ray
P.S.
Don't be stingy on the water!!!!!
stickdog
Somewhere, USA
Posted: 07/29/12 11:06pm Link  |  Print  |  Notify Moderator
Charmin Basic, soft enough for her, tough enough for me.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Pangaea Ron
Anacortes, WA, USA
Posted: 07/29/12 11:28pm Link  |  Print  |  Notify Moderator
We use Angel Soft both at home in the septic system and in the RV... even though Mr. Whipple's daughter is a good friend of ours.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
horizon36
Henderson, NV
Posted: 07/30/12 10:34am Link  |  Print  |  Notify Moderator
We've been using Charmin for the two years that we have been full timing and have had no problems. As others have said use plenty of water. I also flush our tank every time we dump it.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
ken white
Ohio
Posted: 07/30/12 01:07pm Link  |  Print  |  Notify Moderator
A simple TP check is to take a piece of your preferred brand of toilet paper and place it in a glass full of water and shake it up to see if it dissingrates. If it does, it will be safe to use. If it stays intact, then it may cause black tank issues.
© 2016 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
