angler
WI
RV particulars 2002 Allegro Bay
Driveline Workhorse 24K Allison 8.1
Miles:83000
Year:2002
Break Down Description: No start
Symptoms: No Start in front of my house ready to travel. Started 5 times the same day.
Effect: No Cranking just silence.
Cause: Starter relay female connectors in the fuse box are worn.
Outcome: Call roadside since it was so cold the hood wouldn't open. 986 dollar tow bill. Thank you roadside assitance.
Had to bend pins on the starter relay for better connection. until connectors in fuse box can be replaced.
2020 Jayco 34RSBS
2002 Tiffin Allego Bay
2010 Keystone Springdale 29bhssr
1998 Jayco Lite 244
Living-R-Dreams
Wisconsin
We're Looking at a Gulf Stream 36' Sun Voyager Class A. Lots of Xtra's. They are asking $13,000. It has 52,690 miles. Anyone have an opinion?
Prof_Turby
North Carolina
2006 Bluebird Wanderlodge 450 Lxi...
Issue 1: Low fuel...
Picked up the coach yesterday...
Coach had about 1/8 tank of fuel showing so we purchased diesel 10 miles from the sellers home...
Coach would not restart when refueled...
The coach dumped the air and tilted to the left...
The fuel pick up tube is in the right side of the fuel tank...
Local mechanic got the coach cranked after using starting fluid...
Issue 2: Low air in tires...
When we got the coach we gauged the tires and they were low...
Not flat but low...
When we got to the filling station we planned on airing them up but when the coach tilted to the left and would not crank the left rear outside tire unseated from the rim...
Called a tire service truck that got us going...
Two things to remember...
Keep the fuel full and tires aired up...
edited 11/17/19 05:57am by Prof_Turby *
ppine
Northern Nevada
Most breakdowns are random and hard to predict.
Most places in the WEst, you will be a long way from help.
smartmahabub
CA
I went and looked in the battery compartment and saw that the battery was probably loose and was shutting down against anything, but they were fine. Check all screws and especially the plugs that attach the harness together.
pastorm
McKinney, Texas
Hi!! We are in the research stage of buying a Class A gas - can anyone give me an idea of what insurance cost would look like - ....
1/2 Canadian
Clackamas, OR, USA
Pastorm, you need to post this as a brand new thread under Class A Motorhomes.
This one is for relating specific experiences with your motorhome. Read it’s first post(s) from 2003 that explain that purpose.
Otherwise. Admin.: please move post to appropriate category.
edited 11/05/20 10:21pm by 1/2 Canadian *
1/2 Canadian
1984 Pace Arrow traded for
2006 Beaver Monterey
1997 Ford Explorer Limited 4X4
Flyfishing in my blood
Good Sam Life Member 1334373, 35 yrs. RVing
Family Motorcoach Member F384437, Beaver Ambassador Club 14 yrs.
