RV.Net Open Roads Forum: looking for owners of 2004-2005 Pace Arrows
 > looking for owners of 2004-2005 Pace Arrows
Page of 195
Jim Bakker
Carmichael, CA, USA
Posted: 03/31/15 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the under-cabinet halogen bulbs with LEDs? Did you have to remove the reflector? If so, how? My reflector is a bulky piece of pot metal so the tabs that clip into the plastic housing cannot be flexed. If you have been able to remove this type of reflector, please tell me how to do it. Thanks!
Jim and Suzi Bakker
Carmichael, CA
2004 Pace Arrow 36B, Workhorse W22
Ultrapower upgrade
2006 Honda CR-V
Fyr guy
Lancaster, CA
Posted: 03/31/15 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Jim, I replaced all my indoor halogens with LEDs. The replacements do protrude a bit so the reflector will not seat flush against the wood but for me the trade off was acceptable. I just left the existing reflector in place. Hope this helps.
"Patriotism is not a short and frenzied outburst of emotion but the tranquil and steady dedication of a lifetime."
-Adlai E. Stevenson, Jr.
2005 Pace Arrow 37C "Bronze" Workhorse 8.1 "Ultrapower" upgrade
2004 Honda CRV
darbiokc
Oklahoma city
Posted: 04/24/15 11:46am Link  |  Quote  |  Print  |  Notify Moderator
We just purchased a 2004 37a. Seems to be very well taken care of and everything in working order with walk thru. We will be taking our first trip May 23rd. Any comments or suggestions on things to check or do
Fyr guy
Lancaster, CA
Posted: 04/24/15 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome darbiokc! The best advise I can offer is to read this thread from beginning to end to educate yourself with all the issues, suggestions and feedback on learning all about your rig. Good Luck and enjoy your "new" motorhome.
Jim Bakker
Carmichael, CA, USA
Posted: 04/24/15 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.I bought the smallest LEDs available from M4 Products and they fit fine.
Fyr guy
Lancaster, CA
Posted: 12/28/16 11:16am Link  |  Quote  |  Print  |  Notify Moderator
It's been a long time since I've seen a post on this thread but I need to ask for someone's help. I've had this god awful squealing while extending or retracting my bedroom slide and I need to know how to get to the slide mechanism under the carpeted board. Any help/advise/pictures, would be greatly appreciated.
outofplace
Akron,Ohio
Posted: 12/29/16 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
I will be interested to find out how you access the mechanism as my bedroom slide creeps back in after you extend it against the exterior .... once you let off switch the slides comes back in just a tad
* This post was edited 12/29/16 07:30pm by outofplace *
Paul
2016 Outlaw 38RE
tropical36
Southwest Florida_USA
Posted: 12/30/16 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Is the electric brake in the on position, as it should be and does the slide maybe drift open a little when going around a turn?
The motor and drive gear, should be under the bed, as it is for most.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Fyr guy
Lancaster, CA
Posted: 12/31/16 10:17am Link  |  Quote  |  Print  |  Notify Moderator
SUCCESS!! I ended up using a small pry bar to lift up the excessively stapled carpet off the plywood and found 1 screw at the foot of the bed in the center (under the carpet). I lubed (silicon) all the plastic wheels, teeth on track and anything I thought would produce a squeak. This cured my problem! The plywood board bends up enough to get to all the important lube points. I replaced the solitary wood screw with a cabinet handle backed by a small washers so I can access this mechanism in the future. Better to have done this at home instead of an emergency on the road. Thanks again for your suggestions.
seatec
Clearwater, FL
Posted: 05/21/21 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Lets see if anybody still watches this thread. just had tires replaced and saw the front bump stops are rotted. anybody know the part number or good replacement bump stops?
Anthony
06' Pace Arrow 37C
2 Shepherds
2 Pugs
Page of 195
