Rather B Fishin
West Valley, OR
Anyone have pics of a set of camper stands that you have built out of wood? 4x4's or 2x4's?
I'm looking for ideas. I'm using jackstands but want something taller yet strong that I can build myself.
Any help is appreciated.
2017 F350, CCLB, XLT, 6.2L, 4.30's
2005 Four Wheel Camper - Grandby
2020 GD Reflection 337RLS 5'er (for sale)
Going back to a truck camper...
SoCalDesertRider
Arizona desert
I don't have any pics, but I've seen alot of campers sitting on sawhorses.
I keep mine on srew-type trailer leveling stands with 4x4's on top to spread out the load and 2x12's underneath to keep them from sinking into the dirt. They work great for leveling the camper when it's off the truck and I stabilize it with the camper jacks.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
mountainkowboy
Socal/NE Oregon
Here's some
Chuck & Ruth with 4-legged Molly
2007 Tiffin Allegro 30DA
2011 Ford Ranger
1987 HD FLHTP
Kodiak K99
Sask. Canada
Thanks Big Redneck
I'm not a carpenter but a carpenters son. I did watch and learn
what my dad was doing.
Mike
PapawFor2
Az
For my prior cabovers, I built a pair of saw horses very similar to Kodiak's only I bought metal saw horse bracket kits to connect the flat bench and legs together. The height of mine was a few inches shorter than truck bed height. That way, removing or installing cabover required very little raising or lowering. When cabover sat on stands, I always kept a little pressure on the cabover jacks for added safety.
Kodiak K99
Sask. Canada
The saw horses are made with 2x4 support 16" high. The top is made up
with a 2x8 with a 2x4 running on the middle under side. Every thing
is attached with screws.
[img]http://pic15.picturetrail.com/VOL628/2685851/5365360/68973374.jpg
Note: Due to invalid formatting, all formatting has been ignored.
Kodiak K99
Sask. Canada
Big Redneck
Waynesburg,Pa.
Those saw horses are super and I am going to make a set for my camper.Thank you for the nice pictures.You done good and If you were here I would give you a cookie.
Philcapt
Troy, NY
When I had my old camper with the hydraulic jacks I used to take 2 steel 55 gal drums with something like a 2x8 at least the width of the camper on each one I placed one in front of the camper and one as far back as pratical with out interfering with holding tanks etc.I would make suree the drums were sitting level . I would lower the camper on to these and leave the jacks down to stabileize the camper. I would shim where necessary. This saved me a lot of jacking. I used this system for over 10 years with no problems
Mister Blue a 2009 Ford F450 4x4 Kings Ranch dually with off road package
2002 Lance 1025 camper
2009 Jayflight bungaow 40FER
1991 Slyvan 21' Off Shore fishing boat
Reddog1
El Dorado, CA
Kodiak K99 has a great looking set of sawhorses. I would suggest that you use bolts (not screws) where possible. I have seen more that one sawhorse give up over time when screws were used. The taller the sawhorse, the more important the bolts. Using the camper jacks as a safety is great.
About a month ago, one of my neighbors had an older camper for sale for $2000. It was on saw horses (about two feet tall) with jacks down. A sawhorse gave up, camper went down, tore off all four jacks due to going down on one side. He loader the camper into a dumpster with a backhoe. Needless to say, didn't get $2000.
I should point out his camper was sitting on dirt.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
