RV.Net Open Roads Forum: The Search Engine, a Tutorial
Search only in Forum Posting Help and Support
Open Roads Forum  >  Forum Posting Help and Support
 > The Search Engine, a Tutorial
Steve Sheree
Raleigh, NC
Posted: 04/24/12 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Is it possible to search for members in certain areas such as city or state?
pulsar
Lewisville, NC
Posted: 04/24/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
No. The search engine can only look at the subject lines, the body of posts and the author's username.
Tom
Rithum64
Pisstburg
Posted: 03/06/14 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I want to purchase a inverter generator for my 5th wheel, it's a33 Cameo 2001 model 50amp, i'm just learning of the amps issue so if some one could point me in the rite direction I would greatly appreciate it...
2oldman
NM
Posted: 05/25/17 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Workaround for finding posts the search engine cannot
memilanuk
Dry side of the Cascades
Posted: 08/20/18 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Is there a specific reason the search engine is so... limited?
I mean, using Boolean operators is a pretty basic functionality provided on almost every search engine on every forum I've encountered in recent years - and I get around a bit. Full regex might be asking too much (more so for the users than the software), but Booleans are pretty bog standard...
smartmahabub
CA
Posted: 12/24/19 03:11am Link  |  Quote  |  Print  |  Notify Moderator
Enter the keyword or phrase you want to search for. If you start searching from within a forum, there is a checkbox bellow the input field that will allow you to restrict it to only that forum. Clicking a checkmail in that box will limit the search, otherwise all forums will be searched. Click go to the right of the input field to start the search. It does not search for signature and profiles. The following tutorial shows you how to use search engine.
