RV.Net Open Roads Forum: General RVing Issues: Awning mold
 > Awning mold
jeb5
Western Ohio
Posted: 05/20/05 10:50am Link  |  Print  |  Notify Moderator
If you ever use Mr. Clean Erasure, you will NEVER use anything else. It is very easy and the results are WONDERFUL!
Happy Trails.
Ford F-350, 6.7 Diesel, 4x4, Long Bed
Newmar Kountry Star 5th Wheel
rsday75
Mills River, NC
Posted: 05/20/05 12:21pm Link  |  Print  |  Notify Moderator
Another hint I can at is to use the 303 protectant on the awning once it is clean and dry. I have done this on both our oul and new camper. Mold doesn't seem to want to grow on an awning coated with the 303. I coat both the outside and inside of the awning. I also do our slide toppers.
2003 GMC Serria 2500HD D/A
2016 Jayco 355MBQS
Stefan
Calgary, Alberta, Canada
Save money and use regular bleach. All branded products are various forms of cleaners. Bleach is required to kill the spores to prevent regrowth. After that though mold comes off fine with just the hose and a brush....
Stefan
2003 Chevy Silverado 1500HD, 3.73, 4x4, Crew Cab, 6.0L (loving it!)
2003 Layton lite 232 BH
DrTanTodd
Sioux Falls, SD
Posted: 05/20/05 12:27pm Link  |  Print  |  Notify Moderator
An easy way to wash your awning is to use good hot soapy water get it on the awning good then roll up your awning and let it set for about 20-30 minutes (better if you do it on a warm day). Then unroll the awning and hose it off. Usually very few spots that you have to use a brush on.
Todd
Todd and Dawn
Maddy and Nugget the Cats
2014 Dodge Ram 2500 Diesel
2015 Jayco Pinnacle 31 RETS
Irish2
Canada
Posted: 05/20/05 02:21pm Link  |  Print  |  Notify Moderator
I have used Simple Green & the Awning Cleaner from Walmart and have found the product from Walmart worked great with very little elbow grease.
2013 Winnebago 42E
2019 Jeep Cherokee Trailhawk
Big dog 04
Eastern Iowa
Posted: 05/20/05 06:44pm Link  |  Print  |  Notify Moderator
A&E says to mix 1/4 cup bleach and 1/4 cup mild dish soap,like Dawn, in 5 gallons of water. Spray on the awning, then roll awning up for at least 10 min. then unroll and spray off. Worked good for me. If need be you could do it a second time.
Big Dog
2004 Winnebago Adventurer 37B
2007 Jeep wrangler Rubicon - Toad
Spoiled Black Lab
 > Awning mold
