RV.Net Open Roads Forum: Class C Motorhomes: B+ motorhomes
Open Roads Forum  >  Class C Motorhomes  >  B+
 > B+ motorhomes
Page of 371
cheeze1
Morristown, NJ
Posted: 07/06/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
My condolences Dale. My wife and I over the last 2 years have both undergone successful (fingers crossed) cancer treatments but the fear is still there.
Agree with Orion, wish I still had my ‘05. I tried to paint my own swoosh on mine and the proportions/curves were so bad I didn’t even try to to the other side. I eventually removed it.
Chas Morristown, NJ
Trail Lite
Scottiemom
Posted: 07/06/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the condolences. Terry kept going a long time even with serious heart problems, but eventually it all caught up with him. It was still a shock and I don't like being alone, but it is what it is.
The other decals on my 213 are in good shape and don't need replacing, just those circular Trail-lite decals. I will try to see if I can find them on line. Didn't even think of that. I figure a graphics outfit could duplicate them. I'll see what I come up with.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
Orion_42
Lakes Region, NH
Posted: 07/06/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Found them here.
https://www.ebay.com/itm/281596233725
Really made a difference. A bit tricky to put on, but patience and maybe an extra set of hands works good.
* This post was last edited 07/06/21 03:43pm by Orion_42 *   View edit history
2001 Trail Lite B+ 211
Scottiemom
Posted: 07/07/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Orion_42 wrote:
Found them here.
Thanks a lot, Orion_42!
cheeze1
Morristown, NJ
Posted: 08/18/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Folks, there’s a we might be getting another B+ or C. Since I’ve been out of the loop since 2012, I don’t have all my RV resources anymore.
We will be looking for a smaller (up to 25’) one with hopefully 1 slide out, rear bed preferred, but we have to be flexible in the used market.
Lower mileage is a plus.
What are the ‘newer’ websites where we might start looking?
Thanks everyone!!
Scottiemom
Posted: 11/30/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hope you guys are still lurking on here. I ended up making a third trip to Indiana from Florida since April. The last one was in September and I stayed almost 2 months. Unfortunately my 96-year old Mom had a stroke, then another, then died. Miss her a lot. Got back home to Florida, stayed a month and now I am on my way to my place in Mission, Texas. My daughter is with me in MinnieMee. Tight quarters for sure, since I have my dog too! I am pulling my 6 x 12 enclosed cargo trailer and so far, so good. Plan on bringing back all my personal stuff and my golf cart.
One problem though, and thought some of you had experienced this. I was doing a walk around the first night out and noticed the spare tire leaning forward. OOPS! Turns out most of the screws that were holding the mounting plate for the spare tire to the coach were pulled loose from the back side of the coach. The material behind it appears to be rotted. There were still screws holding it in and we didn't want to pull, so we first tried to remove the tire from the plate, but of the 2 screws, one would not budge. Those screws were long and I didn't have any long enough sockets to go around it. So we finally were able to get the plate mounting screws undone and got the spare tire off. Put it in the trailer so we are good to go. I covered the area with a plastic cutting mat, duct taped (horrors!) it to the back.
Have any of you had experience with this problem and how did you repair it? I'm guessing the best repair is to replace the entire back with new material, but that would be a job for an expert. I don't know of any other way to carry a spare. I normally carry a trunk on the back Terry had fixed with a custom hitch. It holds all the sewer stuff, water hoses, etc. It slides into the hitch receiver.
Would be interested in what you all might suggest. Thanks!
Dale
cheeze1
Morristown, NJ
Posted: 11/30/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Scottie, I would suggest you carefully remove small amounts of the damaged/rotted area and review the internal construction. You might be able to remove a section of of the fiberglass and replace all the rotted sub framework, and then go over it with new fiberglass sheets?
Scottiemom
Posted: 11/30/21 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply, cheeze1. Once I get to my place in Texas tomorrow, I thought I would take the patch off and let it air out and take a better look at it. Where the screws pulled out looks pretty crumbly. I'm thinking whatever needs to be replaced can be covered by maybe a larger bracket for the tire. But none of this is anything I could do. Prolly should have the roof resealed, although I haven't seen other evidence of any leaks. It may be the caulk around the spare tire mounting plate failed and allowed moisture inside. Thanks again.
Dale
Scottiemom
Posted: 12/14/21 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Just got back from a whirlwind trip to south Texas. Drove MinnieMee, my 2004, R-Vision Trail-lite 213, from my home in Florida to Mission Texas, a little over 1300 miles. My daughter went with me and I towed my 6 x 12 enclosed cargo trailer. The purpose of the trip was to empty my place there of stuff I wanted and to try and get a sale going before heading back. Wanted to get back in time for my daughter to drive back to Virginia for Christmas with her family.
We left the day after Thanksgiving and because that was such a bad travel day due to traffic, we took 4 days to get there. MinnieMee did fine and pulled the trailer like nothing was there.
We got there on a Wednesday and started cleaning out the shed, etc. Terry and I had already gotten a lot of stuff out of it so this trip was the golf cart, my patio set and anything else I could haul. By Friday I had the Texas room cleaned, so I put a sign in the yard and within an hour I had lookers. They were steady all day and by evening the first looker called me back and said she wanted it. About 20 minutes later another looker came by to tell me the same. No squabbling on price and a cash deal. Long story short, the deal was made and $$ wired and I started sorting the stuff I wanted to take back with me.
While we waited for paperwork, my daughter and I did some sightseeing. The last time she was there she was 16 and she's 45 now, so I showed her a few sights we could squeeze in and she was able to buy some souvenirs for her kids and husband, etc.
Last Friday, three men friends came and loaded my trailer, cart in first, then everything else. Saturday we started back to Florida. Drove to the east side of Houston the first day amid fierce wind. A road construction sign was blown into my side view mirror which closed the arm in and shattered the glass in the mirror as it hit the driver's window. I did not see it coming. I was not out of my travel lane because it was a construction zone and I had a jersey wall on my left and a line of traffic on my right. Fortunately even though I was startled, I kept my cool and continued on. Once we were able to get to a rest area and get out and inspect, I found the only casualty was the mirror and not a scratch or anything else on MinnieMee. I had a makeup mirror in the bathroom, so my daughter and I taped it on the mirror head and I was back in business. That worked the rest of the first day, but we stopped the next morning at a Wally World and I bought a larger mirror and a fish eye lens and gorilla double stick tape and gorilla vinyl tape, all clear, and fixed a better system which allowed me as much vision as before.
I did forget the one other casualty. The spare tire and mount pulled out of the back wall of the motorhome. Looks like the wall holding the huge screws is crumbly and rotted a bit, although the other part of the wall seems solid. We removed the remaining screws that were holding it on and put the spare in the trailer. We caulked the holes to prevent water leakage and I will have to find someone who can make that repair. If any of you have experienced similar, tell me about your repair.
Sunday and Monday I drove almost 500 miles each day to get home to Polk City. I will never drive that far again in one day, but I really wanted to get back home. We arrived at 5:30 last evening, still light out. My daughter, to whom I am forever indebted for making this trip with me, insisted we unload the trailer last night. We did. By 8:30 we had the top back on the golf cart and took a ride around our park to look at Christmas lights.
The entire trip from Florida to Texas and back was 15 days and over 3000 miles, half with MinnieMee pulling a loaded trailer. She did great, never once overheating or even hinting at it. Trailer pulled straight and true, and although the cart had shifted in the trailer, everything made it through with maybe a scratch or two, but intact. And my place in Texas is sold, $$ in the bank.
I was so glad to get home without any more problems than I had.
This was the last "loose end" I had to tie up since Terry's (Teacher's Pet) death in October 2020. From now on, my trips will all be for pleasure. We had planned to do this trip in October, but my Mom passed away and I spent two months before/after her death in Indiana sorting things out. No way did I think we could get it done between Thanksgiving and Christmas, but that was the only time we had due to other commitments.
Safe travels everyone!
Dale
cheeze1
Morristown, NJ
Posted: 12/14/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Dale, so sorry to learn about Terry. My sincere condolences.
You took care of a lot of ‘business’ on that tiring trek, time to get MinnieMe fixed and relax!
Page of 371
 > B+ motorhomes
