RV.Net Open Roads Forum: Fifth-Wheels: Thor 2004 Wanderer Wagon Recall
 > Thor 2004 Wanderer Wagon Recall
treborg
Bakersfield, California
Posted: 08/08/05 04:32pm Link  |  Print  |  Notify Moderator
Has anyone else received a recent recall from Thor regarding your 2004 Wanderer Wagon?
The axle hangers are defective and can cause handling/stability problems at freeway speeds. I took my trailer to my dealer to have the recall taken care of and they discovered that I also have a bent frame. (a rather severely bent frame) The dealer told me that it is unsafe to pull and Thor was contacted. I have been given the run around and they finally sent a crew up to the dealer to take care of the recall and fix the frame problem. The crew showed up with only a welding torch, completely unprepared to fix this problem. It has been indirectly told to me by Thor that maybe I caused the bent frame as it was not caused by the axle hanger problem. I have never had it off road and taken very good care of it, after all it only cost $38,000 and I can't afford to abuse it. My dealer thinks the axle hanger situation caused the frame problem.
My concern is safety as I take my kids, grandkids and the family dog when we go. I'm very uncomfortable with the whole situation. What do I have to accept as a consumer? I really don't think I have to accept a trailer with a "repaired frame" especially after spending as much as I have for this unit.
There solution is to cut about 10 feet out of the frame and weld in a new piece!
Seems to me that would weaken it further. I'm not an engineer. I'm thinking about consulting an attorney. Any advice would be greatly appreciated!
Thank You
corgihauler
Posted: 09/05/05 05:58pm Link  |  Print  |  Notify Moderator
Hi. Welcome to RV.Net!
Up in the search box, type bent frame. There are 30+ items displayed under that topic. Hopefully there is some information to help you.
Jan
corgihauler
truck & tt
indiana* iowa* ohio* tennessee* georgia* florida
