RV.Net Open Roads Forum: Truck Campers: TC Rear decking
 > TC Rear decking
Popkorn
Ft. Collins Colorado
Posted: 08/12/05 11:52am Link  |  Print  |  Notify Moderator
There have been a number of postings about building a rear deck for our TC's. I'd like to add mine off the back of my Bigfoot and ask a question. My design was almost perfect as to size, alignment and fit.
It even looks good tucked up and secured in the travel position
....but, it is too weak and flexes in the middle so that I'm afraid to stand on it. What gage angle iron have others used? The frame is 1/8" flat plate bent at a 90 degree angle.
So, this one will be trashed and another welded up from heavier angle.
Jerry Crawford
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Gregori
San Diego, California (USA)
Posted: 08/12/05 12:06pm Link  |  Print  |  Notify Moderator
No need to pitch this one, just add two lengths of 1.5" square tubing (.120 wall) across the width, dividing the depth into thirds. I think I paid about $25 for a 20' length of this stuff recently - not a big deal.
You could go bigger/heavier, if you're a 'big' guy, but two .120/1.5" box sections will support a fair amount of weight, even with the 8' span.
(If you make it TOO heavy, it will be a hassle to stow/deploy.)
Best of luck,
G.
(Fixed dimension, on edit.)
* This post was edited 08/12/05 03:04pm by Gregori *
'05 F350 DRW - CC/LB PSD 4wd 6-spd, Superhitch + Torklift tiedowns
'97 Lance, shopping for a 5th wheel bunkhouse...
...going nowhere in particular, but making good time...
Popkorn
Posted: 08/12/05 12:14pm Link  |  Print  |  Notify Moderator
Hey - great idea. I'll do that today. Sometimes I'm just too close to the problem to see simple solutions. Gottaq buy some more drill bits though - I wore mine out drilling all the screw holes in the frame [emoticon]
Pete_k
Stantonville Tn
Posted: 08/12/05 12:22pm Link  |  Print  |  Notify Moderator
If it was mine. I would have also ran the boards long ways. The SQ tubing will help. but if you take 5/4" decking boards and run the long ways. It will stiffen it up better.
Pete
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
1995 Kenworth T600 Areocab
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
XA4AV8R
Kennewick, WA, USA
Posted: 08/12/05 12:34pm Link  |  Print  |  Notify Moderator
Your design is similar to mine....I ended up needing 2 full length stringers of 2x2x3/16" angle iron placed about 6" from the rear and front of the deck to get it stiff enough...plus my frame is a little beefier than yours...1.5x1.5 angle. Mine is quite strong...I hauled a 240 lb Honda 250 motorcycle on it last weekend and it supported my weight on there also![image]
* This post was edited 08/12/05 12:48pm by XA4AV8R *
'97 Dodge 3500 4wd '99 Northern-Lite Ten 2000CD
Gregori
Posted: 08/12/05 03:07pm Link  |  Print  |  Notify Moderator
I was going to say something about the board direction, as Pete K. pointed out, but those look like 3/4 inch boards, not 5/4 inch decking.
Also - I intended to say 1.5" square tubing, but inadvertently put 1" in my post. (Now corrected.) 2" would be even stronger, but at the expense of weight and cost.
G.
Popkorn
Posted: 08/12/05 04:04pm Link  |  Print  |  Notify Moderator
Yes, they are 3/4" cedar decking. I was trying to fabricate something that was a balance between light weight and durable and I went too far in the light weigh direction. I think this will work for me OK.
I went over to the iron monger this afternoon and had two 1" square tubing welded into place. That makes the deck stiff enough but there is still some flex.
Mine locks into place securly while traveling.
Popkorn
Posted: 08/13/05 02:08pm Link  |  Print  |  Notify Moderator
Back to the steps.
I'm in a quandry about mounting/attaching the steps from ground level to the deck. I don't have any problem laying out & designing the three step frame but I've got a mental block about how to attach them at the top/porch. I had intended to hinge them so they laid against the porch when up in travel position but after I did the math the step stringer is right at 42" (Hypotnuse of the triangle - the porch is about 32" high). This is too long to hang/swing down on a hinge as the bottom would be only a few inches above the ground.
Until I can work out these details I'm going to have to carry a small two-step ladder to get up and down. I laid out the steps on a 45 degree angle, mostly so LOML can step with confidence up to the porch. I can recompute the angle-of-the-dangle which would make the steps steeper (and a correspondingly shorter stringer) but I don't think I'd gain enough to make it worthwhile.
Comments - options - thoughts???
* This post was edited 08/13/05 02:15pm by Popkorn *
Artum Snowbird
Campbell River, B.C., Canada
Posted: 08/13/05 03:18pm Link  |  Print  |  Notify Moderator
Snowbird steps are a two part system. When the camper is in the truck, the steps are straight, but when the camper is on the ground, the bottom half of the steps is hinged, so the bottom steps are under the camper.... The bend under part forms the step foot.
There are two short stubs out to the sides at the top closest to the deck, and these would fit into "U" shaped slots welded at 90 degrees outward to the outer edge of the deck
Not sure if this would work for you, but it might. Need a better desc, I will take a pic of a drawing so you can understand.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Popkorn
Posted: 08/13/05 04:26pm Link  |  Print  |  Notify Moderator
I think I got it. Sometimes when I have a knotty problem to solve (like peace in the middle east) I go for a drive. Often that clears my head and a solution will come to me. I did that this afternoon and I think I have a plan. If it works I'll post it - if not I'll go soak my head.
 > TC Rear decking
