Spott
SE Michigan
This meter project is attributed to kermitdafrog (go here then ricks stuff, motorhome, meter project)
Here’s my wireless thermometer, thermostat & meter panel w/charge wiz.
![[image]](http://i25.photobucket.com/albums/c68/spottt_/DSC01916Small.jpg)
Running the wires was interesting because the studs run horizontal instead of vertical. I was having a hard time finding a way to route the wires and was about to give up until I started playing around with the digital camera, I would reach into places I could not see but I could stick my hand. I could then see tanks & wiring
![[image]](http://i25.photobucket.com/albums/c68/spottt_/DSC01860Small.jpg)
![[image]](http://i25.photobucket.com/albums/c68/spottt_/DSC01866Small.jpg)
and I found a very large empty cavity behind the pantry in between the bath and the dinette. This empty space ran all the way from the ceiling to the floor, right next to the converter. So I ran the wires here.
![[image]](http://i25.photobucket.com/albums/c68/spottt_/DSC01869Small.jpg)
Here I added an outlet for the wall wart, two shunts and an 8 wire splice for a quick connect.
![[image]](http://i25.photobucket.com/albums/c68/spottt_/DSC01884Small.jpg)
I still have to finish wiring the Amp meters but wanted to take a break
last
edited 04/03/06 06:52am by Spott *
View edit history
Me - Kim - Spot
fast.5
Ontario, Canada
Hi: Nice looking job, it appear from your pic's that you have already found your next project- making use of that empty space. Camera's are great.
Mike
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension.
2007 LANCE 1131 Loaded, Air,Dicor,all weather packages Awning&Slide awning,2500lp Onan camp power,back up camera,dish
Fast.5 Reno Page http://community.webshots.com/user/fast5
hwybnb
Nice work. What did you use to apply the lettering on the meter panel?
Spott
SE Michigan
hwybnb wrote: What did you use to apply the lettering on the meter panel?
I used a Brother P-touch lable maker.
bbnate804
Delaware
you just saved me an hour on my next mod. it would've been years before i thought to put my camera where my head didn't fit. i've tried using the mirrros and lights but thats a pain.
nate
2003 GMC Sierra 2500HD 6.0 4x4
1989 Hideaway 951RD
AMSA 1410
no kids, no pets, 1 wanna-be wife?!
Testudo
Germantown, MD
Hey! Sweet control center!
Testudo & Princesse Caribou
2012 FORD F-250 6.2L 4x4 EC SB SRW
2006 FORD F-250 5.4L manual trans (Sniff! Gone but not forgotten!)
2006 OUTFITTER SUPER-Caribou 6.5
wsdepa
Raleigh, NC
Looks great. I want to mount a wireless weather station as well and I can not figure out the best place to put the remote where it will be clear of the temperature effects of the truck or camper. Where did you put yours? Thanks.
2006 F-350 S/C 6.0 DRW 4x4 3.73, 2005 Lance Max 981, most options. Camped 49 states and all Canadian Provences(cept Labrador). 100,000 miles and 500 plus nights of TCing.
http://truckntravels.blogspot.com/
Allen Schultz
Divide, Colorado USA
My digital camera has a video out jack. By running a cable to a TV or monitor you can push the camera further into the cavity.
Nice job on the panel.
02 K2500HD Crew Cab Duramax Long Bed. Rickson 19.5" wheels + Bridgestone R250's. Rancho 9000's, Hellwig Sway Bar & Leveling Springs. 02 Summerwind 8.5 Camper with extended cabover. Honda EU3000 runs 13,500 AC.
Testudo
Germantown, MD
What does the on-off switch do???
You pretty much have a meter setup like I want.
I assume the DC amp meter labeled "DC amps" is for the load amps. Why did you use a +-ranged meter for the loads? Wouldn't it have been less money for a +range on that one? Do you have negative loads?
Xpltivdletd
OH, U.S.A.
More applause on your digital camera work! Add to that, I have a P-Touch™ #PT-65 and know how easy it ISN'T, to get those labels on straight & centered sometimes. Nice work.
