RV.Net Open Roads Forum: Class A Motorhomes: FORD RADIATOR FLUSH?
 > FORD RADIATOR FLUSH?
BillArf
NY and Florida
Posted: 05/06/06 06:05pm Link  |  Print  |  Notify Moderator
The upper radiator hose is connected to the water outlet connection which is that elbow that bolts onto the upper intake manifold.
Remove the 2 bolts from the the water outlet connection and remove the outlet connection.. After removal of the water outlet connection, revealed is the thermostat. The thermostat uses an O-ring seal. Ford recommends you replace this o-ring seal when you fool with the thermostat.
This thermostat install pic shows water outlet connector removed
A= O-ring
B= thermostat
C= upper intake manifold
* This post was last edited 05/06/06 06:28pm by BillArf *   View edit history
