RV.Net Open Roads Forum: Class A Motorhomes: oil consumption
 > oil consumption
TheElmores
N.C.
Posted: 03/15/02 08:07am Link  |  Print  |  Notify Moderator
Mr. Ed;
Our 8.3 Cummins uses no oil between 3000 mile changes with Shell Rotella at 87000 miles.
Theelmores
94 Monaco Executive
PS: leaked some a time or two but got those
stopped.
MNoel
Meridian, Idaho
Posted: 03/15/02 08:15am Link  |  Print  |  Notify Moderator
My V-10 has not used any oil between changes every 3000 miles. I use whatever is on sale, mostly quaker state or valvoline.
MNoel
03 Southwind 37U W22
98 Durango or 20' Mariah on Behind
dolce far niente
JoeG
Henniker, NH
Posted: 03/15/02 10:57am Link  |  Print  |  Notify Moderator
My first class A was a Chev 454. Sold it at about 60K miles. Used less than 1/2Q between changes at typically 3,000 miles.
My present class A is a Ford, 460, with about 40K miles. This uses no oil that I can detect between changes.
I use Amzoil (spelling looks wrong) 15-40 in the summer, 10-30 in the spring and late fall.
Joe
rvten
Crossville,TN
Posted: 03/15/02 11:17am Link  |  Print  |  Notify Moderator
I have noticed that depending how one drives will also effect oil useage. Flat land driving is easyer on the engine. Pulling a toad or heavy trailer and big hills will make the engine work harder, run hotter and tends to make the engine use some oil. Most engines will use about a quart between oil changes.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
lluttrell
Longmont, CO
Posted: 03/15/02 12:37pm Link  |  Print  |  Notify Moderator
We have had the Ford V-10 in two rigs, and I have yet to add oil between changes. I think it was down about half a quart when I changed at 4000 miles. Currently using Motocraft 5W-20, just like the book says to do.
Lyle & Marilyn
2013 Itasca Cambria 27K
mr. ed
Amarillo, Texas
Posted: 03/15/02 04:57pm Link  |  Print  |  Notify Moderator
Thanks for the response, fellas. I thought I had a real good thing going, but it seems that many of you are getting decent mileage from your oil. Of course, low oil consumption is a sign of a good engine. I remember about 2 yrs ago, I was taking a trip to AZ from CA. Hadn't taken a long trip in quite a while. I was suprised to see quite a bit of oil consumption at the beginning of this relatively short trip. After a little while, though, the excessive consumption stopped. I can only surmize (sp) that since I hadn't really run it for a while, the rings had to reseat (?). Anyway, I'm pleased. Happy rving to all of you.
Mr. Ed
Ipanema
Punta Gorda, FL
Posted: 03/15/02 05:06pm Link  |  Print  |  Notify Moderator
Mr.ED:
On our Ford 460, we hardly need to addoil between oil changes. Maybe....MAYBE....a 1/2 Qt in 5,000 miles. Thank God because I've heard some horror stories!
Ed and Lilian
Penn State Class of 1956
Old Snipe
Full Timer
Posted: 03/15/02 05:52pm Link  |  Print  |  Notify Moderator
2001 Ford V-10, using the factory recommended 5W-20. Was concerned about oil consumption when engine was brand new, but now at 5800 miles, have not used a full quart in almost 3000 miles. Ran VA-FL-VA in January at 60-65 MPH, too.
Paul D
2001 Four Winds 31Z (aka "R SANITY")
Bill S.
Delaware
Posted: 03/15/02 06:52pm Link  |  Print  |  Notify Moderator
Just returned yesterday from a Delaware-Key West-Delaware trip and used less than a quart. 2001 V-10 has only 6500 miles on now.
Bill, (aka Capt.Bill)
2002 Horizon 36LD, Cat 330
RVing since 1987
First State
JR3
Okla
Posted: 03/16/02 06:46am Link  |  Print  |  Notify Moderator
Mr. Ed
My oil usage depends upon my right foot ! My 89 454 (60-k) uses about 1qt every 1200 to 1500 miles if I drive 55 mph. At 70 mph during the summer 1qt every 600-800 miles is not uncommon.
I also use Vavoline Syntec 10w30 9 months out of the year. During the summer I change to 20w50 it seems to cut down on consumption.
 > oil consumption
