RV.Net Open Roads Forum: Truck Campers: happijac cordless drill attatchment
 > happijac cordless drill attatchment
ktimm
Austin TX
Posted: 08/15/06 07:36pm Link  |  Print  |  Notify Moderator
Anyone know where to get the attatchments to run the jacks up and down quickly with a cordless ? I checked the happijac site and saw no mention
thanks
Fire Instructor
Upstate (Albany) NY Area
Posted: 08/15/06 07:42pm Link  |  Print  |  Notify Moderator
I went to the dealer, bought an extra crank handle ($14) and just cut it off with a sawzall. Well worth it, though I find that to get the jacks real snug, I still need to make the last 1/2 turn by hand with the manual crank.
Fire Instructor
2014 Ram Laramie w/6.7L Cummins Diesel with Automated Safety Hitch
2016 Jayco 377RLBH
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
Prominion
Calgary Alberta Canada
Posted: 08/15/06 10:01pm Link  |  Print  |  Notify Moderator
I use an 18mm socket and a 3/8" adapter for the drill...I don't have Happijacs (Palomino B800) but it sure beats the livin cr*p out of cranking....the drill generally doesn't have enuff torque to lift, but its very slick for dropping the jacks to balance the camper on the truck and to drop it onto my little garage trailer.
Professional Minion & Sweetie
cleary
Fairbanks, Alaska
Posted: 08/16/06 02:09am Link  |  Print  |  Notify Moderator
I use a 5/16" X 6" bolt. The bolt head is 1/2" across and fits perfectly into the happijac. I also filed 3 flat spots on the threaded end of the bolt so my cordless can get a better grip on it.
Chuck
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
ronday
Heuvelton, NY USA
Posted: 08/16/06 05:18am Link  |  Print  |  Notify Moderator
Buying the crank handle ($14) and cutting it off is the best idea. The made for drill attach. is $35. Go figure! Ron Day
2008 Chevy 2500HD D/A, Crewcab SB, Pullrite superglide
2011 Big Country BC 3250TS 33ft 5ver
2005 Fleetwood 26ft 5ver
2005 Sun Lite Truck Camper
Ron - 29 yrs HS Tech Teacher (ret) 24 yrs USN/USNR Chief (ret)
Sheila - 29 yrs HS Home and Careers Teacher (ret)
Fire Instructor
Posted: 08/16/06 06:33am Link  |  Print  |  Notify Moderator
Cleary - Thank you for the idea to file down three sides! I'll modify mine tonight! What a great forum. You learn a new trick or two every day!!!
