RV.Net Open Roads Forum: Truck Campers: Outside shower made a bit more useful
 > Outside shower made a bit more useful
Spott
SE Michigan
Posted: 11/27/06 11:11am Link  |  Print  |  Notify Moderator
We like our outside shower but it is a bit limiting because of the short length of the hose, we like to rinse off Spot before he goes into the camper and sometimes a full blown bath.
Since I could not find longer hoses in stores I just modified mine, It now reaches well past the opposite side of the camper. It is now a bit over 20' long. Why so long? Spot behaves much better while getting a bath when he is on a bench and it also makes it easier for us not to have to bend down so far.
I forgot to get a photo while using it so the will have to do.
And yes, all that hose does fit inside. With our camper you push the hose up into the opening at the top of the compartment, it's open inside with lots of room behind the shower.
Me - Kim - Spot
Testudo
Germantown, MD
Posted: 11/27/06 11:29am Link  |  Print  |  Notify Moderator
Another modification I would suggest is to replace the shower handset with a cheap trigger operated garden spray head. Having one with a revolving stream modifier is useful for various stream applications. The trigger spray control conserves water better than the handset control.
To make the modification, all you need is a brass WATTS #A-663 male hose to MIP adapter (3/4" x 1/2"). This item is available in practically any hardware store.
Testudo & Princesse Caribou
2012 FORD F-250 6.2L 4x4 EC SB SRW
2006 FORD F-250 5.4L manual trans (Sniff! Gone but not forgotten!)
2006 OUTFITTER SUPER-Caribou 6.5
Tinner
Holland, Texas
Posted: 11/27/06 11:30am Link  |  Print  |  Notify Moderator
Good job, think I'll modify mine.
Gun Control - Hitting Ones Target
Tinner
belairbrian
Alabama
Posted: 11/27/06 11:34am Link  |  Print  |  Notify Moderator
When we got ours the outside shower was nearly worthless. Took the spray head off to find a restrictor hole about 1/16 inch across molded in. A 3/8 drill opened it up and now it actually works.
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison
2010 Chaparral 268RLE
Reese 16K Slider Hitch, Prodigy 3 BC
USAF Retired
WAR EAGLE
BobTowne
Fairfield, CA, USA
Posted: 11/27/06 12:14pm Link  |  Print  |  Notify Moderator
Our outside shower seems to be fine. We don't need the added length of hose, but we do add privacy by erecting our Outback Porta Privy (about $40) adjacent to the shower door. It's got an opening for the shower head to come through, a couple of ties to tie up the shower head (like in a real shower), waterproof pockets for things one needs to keep dry, and it's "pop-up" style, so it's really easy to put up and to stow.
GreatWhite
2004 Dodge Ram 3500 Quadcab Dually
2004 Alpenlite Santa Fe 1150
The Mad Norsky
Yankton, South Dakota
Posted: 11/27/06 12:26pm Link  |  Print  |  Notify Moderator
My girlfriend is the same way. Misbehaves badly when you bathe her, scratches, claws, tries to get out of the tub. Gets water all over the place.
This might work better for me.
Oh, I suppose I should mention that girlfriend is what my youngest boy named ourWestie puppy. Wouldn't want to give anyone any crazy ideas--then again[emoticon][emoticon]
xp8103
Maine
Posted: 11/27/06 02:01pm Link  |  Print  |  Notify Moderator
I put a shower head holder (like the one on the inside) on the outside, above the back driver's side taillight. With an extended hose, I can stand on my back deck and shower. I also installed a shut-off valve because my OE shower head leaked, even when the little button was pushed to the off position. It works slick now.
Nik
2011 Dodge Ram 3500 CTD "Outdoorsman"
CC, LB 4x4, SRW, 6-spd Auto, 3.73LSD, Timbrens, TorkLifts and HappiJac QwikLoads
2005 Lance 1010
Member - Cape Lookout Mobile Sportfishermen
