RV.Net Open Roads Forum: Truck Campers: where are your air valves
 > where are your air valves
Chewyj
washington
Posted: 02/28/07 02:26pm Link  |  Print  |  Notify Moderator
I'm installing my ride rites. Bags are in, but I have to run the air bag lines and fittings.
Its a manual system, so I need to know where to put the end fittings so I can easily access them.
If I go out the back bumper, wouldn't it be a pain trying to air up after you have the camper on?
I don't have the camper yet, but am looking at 9-10 footers so I'll have some overhang.
Vehicle info 1992 F350 crew cab SRW 4X4
Thanks for any input.
mick2268
Grove OK
Posted: 02/28/07 02:31pm Link  |  Print  |  Notify Moderator
Mine are on the rim of each fender, in front of the tire to reduce the amount of junk thrown at them by the tires. This allows me to make adjustments whenever I need to easily.
BrandonR
Oregon
Posted: 02/28/07 02:35pm Link  |  Print  |  Notify Moderator
I mounted mine under the hood, but I don't like having to plug my air compressor in in the cab then string the cord around to the front with the hood open so I'm thinking of re-locating them to the transmission hump inside the cab.
Brandon Reed
Albany, OR
work2much
On the Road
Posted: 02/28/07 02:43pm Link  |  Print  |  Notify Moderator
I mounted mine on the gusset plate for the reciever hitch. I also iinstalled a comperssor and tank. I can plug the air hose into the back of the truck and air up the airbags, or air up any of the tires. Yes it is a pain to crouch under the truck, but I air up the bags before loading the camper and usually have no need to play with them after that.
http://www.turbodieselregister.com/user_........ery/sizeimage.php?&photoid=14286&width=2
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 02/28/07 02:49pm Link  |  Print  |  Notify Moderator
What about on the outside corners of the rear bumper? You will still have to reach under the camper, but not far and they will be out of sight somewhat.
2016 Ford F-350 Lariat CC 4X4 PSD SRW (any day the 2021 F-350 Platinum 4X4 PSD SRW I ordered will be here)
2016 Montana 3950FL (2) Honda EU2000i's ...and a few antique Allis Chalmers tractors
tmartin000
Washington
Posted: 02/28/07 02:54pm Link  |  Print  |  Notify Moderator
Have had the nipples in three places.
By far the best behind the fuel door.[emoticon]
2001 Lance 835. SOLD
2009 Lance 1191. SOLD
2021 Lance 1172
centurian
langley, b.c.,canada
Posted: 02/28/07 03:12pm Link  |  Print  |  Notify Moderator
In the cab so I don't have to get out to air them. They don't get dirty or ever break off this way either.
98 2500 dodge cummins,airbags,rancho 9000's,E rated tires
9'6'' 2000 Citation,stablelift
sleepy
Oak Ridge,Tennessee
Posted: 02/28/07 03:02pm Link  |  Print  |  Notify Moderator
In the wheel wells. We have more than 550 nights and 35000 miles with no problems... easy to get to but not to vandalize. They are never in the way when the tires are rotated.
I use a good bicycle pump to air them up... a few pumps to 100 psi.
The airbags only hold about a pint of air each. No electric pump to buy or replace.
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
Road_King
Southeast & Western Slope Rockies
Posted: 02/28/07 03:15pm Link  |  Print  |  Notify Moderator
I have mine - for my 5th wheel now - both to the side of the license tag. Not good for a camper - had them in each wheel well then. I sure do like having them both in one place - where ever that is!
Bill
'05 Chev 2500HD D/A 4X4 EC
Michelin LTX M/S LT265/75R16/E, 16X8 Aluminum Wheels
'07 Titanium 30E35TS 5th Wheel - YJ following!
B&W Turnover Ball Hitch with B&W Companion
Trailer - Michelin XPS Ribs LT245/75R16/E
6 Lifeline 6V AGM Bat - Xantrex Freedom 20
jimh425
Western MT
Posted: 02/28/07 03:19pm Link  |  Print  |  Notify Moderator
Inside the fuel door.
