RV.Net Open Roads Forum: Truck Campers: Finding Leaks In Your Camper At Home
 > Finding Leaks In Your Camper At Home
joec
Salem and Lakeview Oregon
Posted: 03/06/07 09:34am Link  |  Print  |  Notify Moderator
So how do you get a high volume of air at low PSI to check for leaks in your camper like seal-tech does without the cost?
While I was finishing the lawn and blowing the clippings off the sidewalk I had the answer to the question of high air volume at low pressure in my hand, the leaf blower could do the job!
So the test would be to cut a piece of cardboard, get a 4” hose and set it up in the holding tank door. I checked all the doors windows and vents to make sure that they were closed. Then after SLOWLY closing the back door on the camper I checked the pressure and I had 20 ounces of pressure inside the camper. The stupid thing worked! It worked great!
So now that I had pressure I could check the camper for leaks with some soapy water in the garden sprayer. There were a few leaks around the jacks and the screws that attached them to the camper and the tail-lights were also leaking like a sieve. The gasket on the left hand side of the cab over window leaks but that just drains into the window cannel then dumps to the outside of the camper. No roof leaks and the new clearance lights are also bubble free.
The Setup:
Leaking Tail Lights:
Leaking Screws On The Jacks:
Leaking Window:
So now I have a simple setup that I can use at home anytime. I will be making a plug out of plywood for the holding tank door instead of the cardboard.
So now you can pressure test you’re camper and find any of those pesky leaks at home and for just about free.
One last thing; if you are going to do this test yourself you assume all responsibility for any damage done by over pressure. Not likely but equipment varies!
* This post was last edited 03/07/07 01:56pm by joec *   View edit history
2006 F-350 PSD DRW - 2004 Eagle Cap 950 - Rancho 9000s - Ride Rites and "> "Homemade Super Bump Stops" ">
BradW
Mayor of Flat Rock
Posted: 03/06/07 09:43am Link  |  Print  |  Notify Moderator
Joe,
Great idea. Thanks for posting it. I added it to the TCU Sticky Thread.
Brad
Wake Up America
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
ogrer
Norwood On
Posted: 03/06/07 09:46am Link  |  Print  |  Notify Moderator
Nice job.....good idea
Bob
Bob & Jan
looney bin
Nevada City, CA
Posted: 03/06/07 09:54am Link  |  Print  |  Notify Moderator
Very good idea, thanks joec!
looney bin
Big Katuna
Deland, FL
Posted: 03/06/07 09:59am Link  |  Print  |  Notify Moderator
So how did you fix your leaks?
My Kharma ran over my Dogma.
Spott
SE Michigan
Posted: 03/06/07 10:31am Link  |  Print  |  Notify Moderator
Great job, wish I had thought of it.
Me - Kim - Spot
vanbikehorse
Green Lane, PA
Posted: 03/06/07 10:47am Link  |  Print  |  Notify Moderator
Great Approach!
Good Caution on the pressure being at the owner's risk. I have one of these. The wife is always complaining about me blowing her plants out by the roots, but I don't have to worry if the leaves are dry or that too many have come down!
PS - I would work on those leaks at the bolts right away. I found rusty threads on my bolts where the sealing had been compromised.
2005 Chevy 2500HD SB X-CAB,4X4,G-80,D/A,ALCOA Wls,265/75R16E, Air Lift Sure Set, SuperSprings, RS9000x, Curt 14108.
2003 Alpenlite Laramie w/X CAB & Polar Cub A/C, Happijac FM, EU-2000.
2000 Brenderup Baron TC Horse Tailer
1996 Arab Endurance Race Horse
joec
Posted: 03/06/07 10:48am Link  |  Print  |  Notify Moderator
I will back out the screws that are leaking on the jacks and use Pro Flex under the heads. The tail-lights will have to come off and be resealed with Pro Flex also maybe some new gaskets under the lenses too.
The window will take more time but that does not leak into the camper is drains into the windows weep holes and then outside. Maybe a new seal?
DoneItAll
Maryland
Posted: 03/06/07 11:21am Link  |  Print  |  Notify Moderator
Great idea! How were you measuring pressure? By the amount of force necessary to close the door? If not that, how?
Thanks for posting this "T/C method" of making something you need for less money. This part of what I see as the T/C mentality.
John & Harriet on the beautiful Eastern Shore of Maryland
2008 F450 4X4 Crew Cab
2008 Lance 1191 w/220W solar
Boundertom
Formerly from Columbus, Ohio
Posted: 03/06/07 11:30am Link  |  Print  |  Notify Moderator
Outstanding idea! I have had leaks on both my camper and motorhome. This should be a great way to help locate them. Thanks!
Tom Thomas
2006 Expedition 39Z- 390 watts solar
2006 Eagle Cap 850 - 260 watts solar
2007 Ford F350- C+C,SRW,V-10,4x4,Aluminum flatbed- Super Toad!
2001 Jeep Cherokee
Other assorted toys!
