Open Roads Forum
Print  |  Close
Topic: SHURflo pump not priming...
Posted By: wp6529 on 03/22/07 08:33pm
I started de-winterizing my camper (2003 Fleetwood Elkhorn LT 8C) today to get it ready for a trip next weekend. I had winterized with the usual RV antifreeze following the instructions in the camper manual.
I drained the remaining antifreeze from the fresh water tank and then filled it with fresh water to begin the system purge. Turning on the pump (SHURflo Classic 2088-422-144) it runs, but it won't prime.
I checked on the SHURflo web site and downloaded all available info on the pump. The documentation has a small troubleshooting section without much detail.
I removed and checked the inlet strainer and found it to be clear. There is water in the tank based both on the tank gauge and the overflow from the vent at the end of filling. The pump connections all seem tight and aren't kinked. Power is clearly fine.
I can't check the pump valves or housing without removing the pump which doesn't look like a lot of fun given the minimal access to it.
I can get a repair / rebuild kit if needed, but I wanted to check and see if this was a common issue with an easy fix (I just got the camper last year) before pulling the pump and rebuilding it.
Thanks,
Pete C.
Posted By: Islandfire on 03/22/07 09:02pm
I have had this happen to me in the past. Just needs a little boost to get primed. Try putting your mouth around the kitchen faucet and sucking in until you get water. Thats usually all it takes to get mine running again
2000 3/4 ton Suburban, 4:10, 6.0
Prodigy brake controller
27 ft 2003 Layton, bunkbeds
Myself, the wife, the 2 monkies/dependents, and the dog!!
Posted By: flhtci-rider on 03/22/07 09:03pm
when u removed the strainer did u open the valve from the fresh water tank to make sure no blockage from the tank or an air pocket
"> 2006 Scepter
2008 24' Haulmark EDGE
2008 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Gen Set
Posted By: Woodpeckertoo on 03/22/07 09:51pm
Sounds like air in the system (pump is airbound). I would recommend Running the pump with city water connected and an inside faucet on.
Posted By: gurn911 on 03/22/07 10:07pm
Possibly a problem with the pump head. I had a crack in mine last year. Not with a problem with winterizing, but pressure from the city water source. Mine was a Shurflo 4.0. Good Luck! Jim
Flagstaff 8528 BHSS 2006 Chevy K2500 D/A CC SB
Pullrite 16K Superglide Prodigy BC
Firefighter/Paramedic
Wife, Cindy
David 12
Matthew 8
Abby golden retriever 13 (in memoriam)
Posted By: dbbls on 03/23/07 07:10am
Try opening a faucet when running the pump. These things can get air locked and are a problem to get primed. There is probably nothing wrong with the pump.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Posted By: Hurricaner on 03/23/07 07:52am
Note: the pump will never prime unless you open a faucet.
Sam
Sam & Kari
Hurricane, Utah
2019 Winnebago Sightseer 33C
Posted By: wp6529 on 03/23/07 09:12am
It's Alive!!!
The sucking on the faucet (with a MightyVac pump) while running the pump worked.
Thanks,
Pete C.
Print  |  Close
