RV.Net Open Roads Forum: Truck Campers: Stuck adjuster knob on Rancho 9000X
 > Stuck adjuster knob on Rancho 9000X
littlebigbar
Victoria, BC, Canada
Posted: 05/14/07 11:27am Link  |  Print  |  Notify Moderator
I've searched the forums but can't find this info, although I recall a recent posting on this issue. Plus I'm still waiting for a direct response from Rancho so thought I'd see if anyone here has solved a similar problem in the meantime.
One of my Rancho adjustable shocks will only go as high as 6 (it was working fine a few months ago). I haven't put a wrench to it as I don't want to force it. I do notice two screws holding the knob onto the main shock. Can this be removed to lubricate/disassemble the adjuster without a) destroying the shock or b) removing the entire shock to fix.
Has anyone solved a similar problem? Thanks in advance.
'01 F350, SRW, CC, 4x4 longbox
Rancho 9000x, Firestone Ride-Rites, factory swaybars
'04 Bigfoot 9.6 and '96 Coleman Cheyenne (popup)
Raften
Northern Calfornia
Posted: 05/14/07 11:55am Link  |  Print  |  Notify Moderator
Happened to a friend, he got lucky and WD40 got it loose. Might work for you.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
needsomefun
Horse Creek, CA
Posted: 05/14/07 12:29pm Link  |  Print  |  Notify Moderator
Those screws are easily removed for lubrication.
BradW
Mayor of Flat Rock
Posted: 05/14/07 12:31pm Link  |  Print  |  Notify Moderator
Yes, you can easily remove the two allen screws and remove the adjuster.
The reason they stick is the piston behind the adjuster lockes up from rust or what ever. Sometime you can free them up. Sometimes you will have to replace the whole shock. Rancho's have a lifetime warranty if you kept the receipt.
Good Luck,
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
davedye
New Columbia, Pa. 17856
Posted: 05/14/07 12:47pm Link  |  Print  |  Notify Moderator
I have a similar problem and mine are they are only two months old. It's only the front ones that are hard to adjust because of the coil spring over them.
Dave
2006 Dodge Ram Dually, 3500 Quad Cab 4X4, 4.10 Gears, Cummins Diesel
2008 Lance 981 Max, Torklifts, Class V Reese Tow Beast with 24" extension, Torklift Stable Loads
2005 Triton DV 176 DV w/150hp Mercury Optimax
gbutala
Colorado
Posted: 05/14/07 12:55pm Link  |  Print  |  Notify Moderator
Yep take the two screws and wash the debris out with wd-40. Mine had some serious gunk in them right out of the box but after cleaning the knobs worked good. I now have them on air and the control is way better than the knobs.
littlebigbar
Posted: 05/14/07 02:05pm Link  |  Print  |  Notify Moderator
Thank you all for your replies. I am working on them now and will reply back shortly on A DIFFERENT THREAD.
SlideInDad
Massachusetts
Posted: 05/14/07 02:16pm Link  |  Print  |  Notify Moderator
I had this problem on my old '01 3500, after 2 years the rears wouldn't go past 7 which was fine since that's where I used them most the time but in the last year I had the truck the passenger side rear would not go beyond 6. Not sure if I ever had that issue in front since I never tried to go beyond 5 up front.
Rancho adjustability is great but they corrode like crazy. After only 2 years the Ranchos on my '01 Chevy 3500 looked worse than the 10 year old Bilsteins on my '94 1500 which is fine since appearance doesn't matter too much for a shock but the knobs getting stuck is a different story. I may try to cover the knobs with some old bike tubes for the coming winter season on my new 2500HD.
2007 GMC 2500HD Duramax CC - 2006 Lance 861
SuperSprings/Airlift/Bilstein 5100/TowBeast/Torklift tie downs
previous setup:
2001 Silverado 3500 DRW Duramax - 2003 Arctic Fox 1150 Dry Bath
Seacraft Skipper
Lakeville, MA. USA
Posted: 05/14/07 02:26pm Link  |  Print  |  Notify Moderator
Slideindad--- that is a really good idea, I might try that myself.
Bob
Seacraft Skipper
"Semper Paratus"
2003 GMC 2500HD 4X4 ExCab L/b Air lift A/B.
2002 Lance Lite 915.
1972 20ft Seacraft Sport Fish.
