RV.Net Open Roads Forum: Truck Campers: The D.U.H. Camper Loading System
 > The D.U.H. Camper Loading System
Page of 6
fishbonz
Summerville, SC
Posted: 05/30/07 07:53pm Link  |  Print  |  Notify Moderator
Speaking as a beginner....
I like it...
and will be adding them to my camper before the next trip.
Thanks
BradW
Mayor of Flat Rock
Posted: 05/30/07 08:06pm Link  |  Print  |  Notify Moderator
So, anybody called a patent attorney?
Brad
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
jimh425
Western MT
Posted: 05/30/07 11:36pm Link  |  Print  |  Notify Moderator
Brad
I think that's too late. It appears to be in the public domain.
c.traveler2
Moreno Valley,Ca.
Posted: 05/31/07 01:02am Link  |  Print  |  Notify Moderator
Great job FarcticOx,simple and it works,
2007 F-250 4x4 /6.0 PSD/ext cab/ 2020 Bunduvry
Lance 815/ 85 watts solar panel (sold)
2020 Bunduvry by BundutecUSA
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
iwon415
Northern California
Posted: 05/31/07 01:28am Link  |  Print  |  Notify Moderator
If I was a manufacturer I think I would be adding them to my next run!!
Great idea, I plan on adding them!
Tim H
BradW
Mayor of Flat Rock
Posted: 05/31/07 04:12am Link  |  Print  |  Notify Moderator
jimh425 wrote:
Brad
That doesn't matter.
Brad
F350OilBurner
Central MA
Posted: 05/31/07 09:32am Link  |  Print  |  Notify Moderator
For those of you going with the 1/2" PVC tube be aware of one thing. It is very tight to the wheel wells and if you are off by any significant amount (1" or greater) you may rip the tube off on the wheel well. I've only loaded once so far with this mod and had no issue but it could happen, so do be aware. I suggest that you measure the distance between your wheel wells and then the width of the camper plus 2". (2" because 1/2" PVC is about 3/4" OD plus the distance the cable tie mounts move them out and times two for both sides.) Subtract the wheel well number from the width number. What ever is left, divided by two is how much wiggle room you will have on each side. It will not be much.
2006 Ford F350 Lariat CC LB DRW
6.0 PSD w/TorqShift 4x4 4.10LSD
Airlift Airbags/SureSet Controller - Timbrens
2007 Lance 1181 - All the Options
Torklift Superhitch/Tiedowns/Fastguns
fishbonz
Summerville, SC
Posted: 05/31/07 09:38am Link  |  Print  |  Notify Moderator
I'm thinking - use 6ft (defective or seconds) fishing rod blanks
Foward mount (maybe small hose clamp) can be set to a size that would allow the conical shape of the rod to slide forward to a predetermined distance yet not come all the way out. Behind the foward mount could be the previously mentioned small pvc. That way as you back up to the TC, the guides would slide back into stowed position. Plus the rods would have good flexibility and should not break or transfer to much force to the mounts on the TC.
Continuous improvement to a great idea.
bigfootford
Fair Oaks, California
Posted: 05/31/07 09:00am Link  |  Print  |  Notify Moderator
This one could make ,"IDEA OF THE YEAR"........
I'm going to do this right away even though I can load my camper in one pass (usually).
I will be using 1/2" pvc for the rod to slide in.
Jimmy likes it!!
Jim
* This post was edited 05/31/07 09:15am by bigfootford *
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
BFlicker
Rockford, MN
Posted: 05/31/07 09:16am Link  |  Print  |  Notify Moderator
Great idea! I gotta add these. My driveway has a slight slant to it...just enough to give me some grief once in a while. I think I'll try with the PVC tubes.
Bruce,Lisa & Fur Babies
Tessy (2 1/2yo Sheltie)Fudge(12yo ToyPoodle-Lisa's">)
2006 Winnebao Sightseer 26P
2005 Ford 250 Super Duty
Page of 6
