RV.Net Open Roads Forum: Travel Trailers: Cool Mods - Thread restored 10/18/2012
 > Cool Mods - Thread restored 10/18/2012
Page of 269
dewey02
Minnesota
Posted: 03/08/18 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Bob 1870 wrote:
Dual Axle Wheel Chocks
I know I know...this has been done a thousand times. I could never find a drawing to answer a few questions I had. So I made this up. I made set of these today and they are pretty slick. I am going o see if I can get the turn knobs (something like these:
https://www.mcmaster.com/#threaded-knobs/=x5lxzi.) I hope it helps someone else. The narrow part of the block was 1/2 grater than the distance between the tires.
Instead of threaded turn knobs, just use a pipe clamp.
Very easy to adjust, and you can have the crank on top or on bottom, whatever is easiest for your trailer.
crazyro
Rock Hill, SC
Posted: 03/31/18 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Well, you guys got me. I had to join the LED strip club... I like...
PennyPA
Out There Somewhere
Posted: 04/01/18 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I trust that all of you with these LED lights around your RV's remember to turn them off at night when you're camping in a campground.
COPD and LVRS
On the Road Again
My Home - 2002 Glendale Titanium, 32/37DS with a basement slide.
Our Home's Leader - Dodge Ram 3500 Cummins Turbo Diesel Dually
Our Leaders - Sam(Bird), Chirp(Bird), Nellie(FAT cat), Lucy(Kitten), Willie(Dog) & Daisy(Dog)
chr$
Arizona
Posted: 04/01/18 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
No. I use them to keep pack rats out. Even the camp hosts tell you to do this.
-CHR$
1996 Safari Sahara Edition 35' Diesel Pusher. Just getting the Solar stuff started.
crazyro
Rock Hill, SC
Posted: 04/02/18 09:44am Link  |  Quote  |  Print  |  Notify Moderator
We do turn them off. I probably should at least keep the amber porch light on...
CA83
Wisconsin
Posted: 04/20/18 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
everymilesamemory wrote:
Installed a Flat Panel in our Bedroom
It has a built in DVD so that saved space and kept wires to a minimum. This is great for laying in bed and watching a movie, and also keeps the walk-around space to a minimum.
Pat
www.everymilesamemory.com
Wondering how to put one of these in on a flat wall with no stud close by, need to put a TV on a wall but don't want to bolt through the wall to the bath room.
CA83
Wisconsin
Posted: 04/20/18 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
CB,
Where did you find a small rack like that. Looking to attach a blue take as well to the back of our new/used hybrid camper saw a few ideas but I like that and put another one on the other side for a cooler or bikes.
myredracer
Langley B.C.
Posted: 04/20/18 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Interior walls could be 3/4" thick or 1-1/2" thick. Ours are all 1-1/2" except for cabinet walls. A bathroom wall can be thicker because there is a vent pipe to the roof in it. If there is an electrical outlet/switch, thermostat, etc. on the wall, remove it to see what the depth is. A wall with a door in it is also thicker.
To find studs on an interior wall, press the wall paneling in to see where it flexes , and where it doesn't is likely where the studs are. Look for the telltale sign of staples in a vertical row. A stud finder may or may not work (have not had luck myself).
What many have done where there is no factory backer plate is use a piece of plywood to span 2 studs and then install a TV mount of your choice to the plywood. TVs used in RVs these days are pretty lightweight.
There are a few locking TV mounts for RVs. Mor/Ryde makes a nice one and is what I used in our bedroom. There is one that is not very good so be careful what you get.
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
DarthMuffin
Driveway
Posted: 05/20/18 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
My fresh water tank drain valve has always been difficult to turn, not to mention hard for my big monkey paws to grab and I can never remember which way is open or closed. The handle finally broke off so I replaced it with a stainless beer keg tap. Big handle and easy to open, flows more, and I definitely know which way is on and off.
https://www.amazon.com/gp/product/B074TD........=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
deltabravo
Spokane, WA
Posted: 05/20/18 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Screen Door handle, applies to ANY RV:
Screen Door Handle upgrade
2015 Nash 17k (bought pre-owned 5/23/18)
Page of 269
