RV.Net Open Roads Forum: Travel Trailers: Cool Mods - Thread restored 10/18/2012
 > Cool Mods - Thread restored 10/18/2012
Page of 270
grandpopsicle
Posted: 08/11/18 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Really like the trick where you use a fuse on the plug to light up the running lights.
Any reason why I can't put a dimmer in line with the fuse?
Never make the mistake of thinking you know everything about something. ">
TobyG
Folsom, Ca
Posted: 08/22/18 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
After looking into all my options for solar and trying to decide if I wanted my panel mounted to my roof for security and simplicity or if I wanted a portable solution. I liked the security of mounting it to the roof but, then what happens when I park the trailer in the shade? On the flip side what if I went portable and someone decided they need my panel more than me?
Which brought me to this idea... If I mounted my panel to a pole, had enough cable to move my panel to the front or rear of the trailer and had mounting points at either end I would be able to minimize the chances of someone walking of with my panel and would have the flexibility to move the panel for the best possible sun. I haven't actually made the mounts for the rear yet but, I will most likely do something similar to the front and use the rear slide frame as a mounting point. The picture with the panel and trailer set up was before I came up with the solution for anchoring the pole with the clamps in the other pictures.
Built aluminum frame using an old satellite dish mounting bracket.
[IMG]https://i.imgur.com/wpL2Cu2l.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image. border="0" alt="[image]">
Panel with frame mounted on pole.
[IMG]https://i.imgur.com/4vwr0xCl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image. border="0" alt="[image]">
heavy duty pole mounting brackets.
[IMG]https://i.imgur.com/Q3mQHpNl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image.[/img]
This is my preliminary test with the solar panel mounted on the pole before I installed the brackets.
[IMG]https://i.imgur.com/UypdYsrl.jpg "border=0""[/IMG] Click For Full-Size Image.[/img]
TobyG
Folsom, Ca
Posted: 08/22/18 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
It doesn't seem to like adding the first attempt without the heavy duty clamps. So, lets try it again.
[IMG]https://i.imgur.com/UypdYsrl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image.[/img]
2Rad4U
I'm to young to be a
Posted: 10/23/18 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Will be making my first mod to my new TT tomorrow. Replacing the 12v stock battery with two 6 volt golf cart batteries.
Chris
2019 Rockwood 2608BS
2018 Chevy 2500HD
2Rad4U
Posted: 10/25/18 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Boom!
* This post was last edited 10/25/18 07:24pm by 2Rad4U *   View edit history
2Rad4U
Posted: 10/25/18 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Best Mod ever!
Before -
After -
Tvov
CT
Posted: 10/26/18 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Nice!
2008 F-250 CrewCab 5.4L,
2Rad4U
Posted: 11/17/18 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Another mod done today. Added a voltmeter to the side of my battery box so I can easily check my voltage on my dual 6v batteries when we're boondocking. In the past I'd have to remove the covers and use my hand held meter. This will be so much easier.
I added a small toggle switch so the meter would not be "on" except when needed.
harley4275
Belle River, On
Posted: 11/18/18 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Did the same thing...sorta. Aded the same gauge but put it right beside the panel inside and hooked it to the live wire in the panel. Did a pushswitchh alao.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
jfkmk
NJ
Posted: 11/27/18 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
RoyBell wrote:
not really a mod but been itching for an ottoman. Went to a couple furniture stores and they had big ones and the cheapest was $350.
Went to target tonight and there it was. On sale for $59. It even has the same stitching pattern!
[image]2016-07-09_09-45-10 by RoyBelluomini, on Flickr
I knew I wouldn't get the same color so I had get something contrasting. This fit the bill perfect. Small enough for the camper but large enough for both or even 3 people on the sofa to use. Lightweight and has storage inside. I will likely make it my new home for the plates and dishes which currently reside under the sofa and is a pita to get. It's dark brown and yes my slide is not out in the picture.
We bought the same ottoman. When not in use, it fits nicely at the end of the bed. I put two eye hooks in the bed frame and use a strap to hold the ottoman in place when traveling. Great place to store boots, blankets, etc.!
Page of 270
