RV.Net Open Roads Forum: Class A Motorhomes: 96 Allegro p30 ball joints
 > 96 Allegro p30 ball joints
FlatBrokeMXdad
purvis ms
Posted: 06/25/07 06:49pm Link  |  Print  |  Notify Moderator
Trying to order moog ball joints for 96 Allegro M-31,95 Chevy P30 chasis, 454, disk brakes front and rear. Trying to order ball joints, Moog lists K6155 for $150 and K6175 for $70.00. Which is correct? Thanks in advance, Russ
blackinwhite50
charlevoix,michigan
Posted: 07/22/07 06:48pm Link  |  Print  |  Notify Moderator
just wondering how much did it cost to replace lower ball joint
calipers stop sticking should i replace anyways also engine light comes on every time i go over 55 mph doest if under 55 WHY
blackinwhite50
charlevoix,michigan
Posted: 07/22/07 06:49pm Link  |  Print  |  Notify Moderator
cost to replace lower ball joint on p30
Takereasy
Posted: 07/22/07 06:53pm Link  |  Print  |  Notify Moderator
For the P32 it's the high dollar one. If you do not get a reply here, then try the Workhorse forum on IRV2. This is where the Henderson and other suspension folks hang out.
