RV.Net Open Roads Forum: Class A Motorhomes: turning radius
 > turning radius
sootslayer
Central Pennsylvania
Posted: 07/27/07 01:05pm Link  |  Print  |  Notify Moderator
I live on a cul-de-sac with nothing in the middle. Just asphault. I had a 2005 33' Monaco Monarch, gaser. Had to back once to stay out of the stones. I now have a 40 KountryStar DP. I just pull in and loop around. I don't even touch the stones. But you must pay attention at all times or you will bump something. I guess it depends on the coach and knowing what your rig will do.
Hank
HENRY P
YUKON OKLAHOMA
Posted: 07/27/07 01:47pm Link  |  Print  |  Notify Moderator
I live on the same type and have a 40' motor home i park with the door side on the street and when i leave i turn as far as i can then back up with the overhang going a little way into to driveway across the street then make my swing with no problem
Henry
Techie
Pahrump, NV, USA
Posted: 07/27/07 02:36pm Link  |  Print  |  Notify Moderator
You should be OK -- just make sure to lift the tag (and wait for it to lift) and go slow...you can always jocky it back and forth as necessary.
Make sure to have someone spot for you and always keep them in sight!
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
 > turning radius
