RV.Net Open Roads Forum: Truck Campers: Jack mount help please
 > Jack mount help please
KMLsquared
Cotati CA
Posted: 08/03/07 01:35pm Link  |  Print  |  Notify Moderator
Hi everybody, I am new here.
I did a search and read all 37 pages for "repair".
Last night unloading for the first time since we bought our 93 caribou the front almost fell to the ground. Both front jacks started leaning the same direction and luckily my wife caught it before it went too far.
I obviously need to investigate my jack mounts. The right front jack pulled away to the right of the camper. The left front jack pulled away towards the front of the camper.
What are the step for determining the nature of the repair? What criteria do I use to determine if I drill some new holes and add screws or rip the siding off and replace the frame work underneath?
Thanks for the help.
2002 HO 6spd LB QC 4x4. Edge Juice w/Att 4" str8 pipe AFE int Skyjacker D25 springs w/10" Fox Shox 2.0 Thuren track bar PSC Steering box w/DSS. Fox Steering Damper w/custom mount.
2003 Rampage 33TB
2002 Banshee
1969 Baja
JoeChiOhki
Sauvie Island, OR
Posted: 08/03/07 03:45pm Link  |  Print  |  Notify Moderator
Get the jack brackets off and clean up the putty. Then check the wooden frame members, they may be dry rotted.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
spkncarl
That Way
Posted: 08/03/07 03:55pm Link  |  Print  |  Notify Moderator
YIKES!!![emoticon]
Good thing it didn't fall on her. Like already mentioned, check for dry rot, otherwise it'll just happen again. Good luck!
tomarn49
Missouri
Posted: 08/03/07 10:02pm Link  |  Print  |  Notify Moderator
Sounds like quite a woman, to catch a falling truck camper! Be real nice to her...
Don-RW
San Diego
Posted: 08/03/07 10:55pm Link  |  Print  |  Notify Moderator
Check thisLINK for photos of wood repair of corner jack
KMLsquared
Cotati CA
Posted: 08/15/07 08:25am Link  |  Print  |  Notify Moderator
Well the wife and I tore into the jack mounts last night. Both front bottom corners have dry rot. The crossmembers and vertical peices are pretty well rotted. The plywood in the wings looks bad too. I haven't pulled the siding off the side yet so I don't know how far down the side it goes. I will take some pictures next time.
What kind of wood should I use to replace the bad wood? What kinds of fastening methods should I use? I like the idea of glueing and screwing it back together. What is a good brand glue to use?
Thanks Kevin
hilandfrog
Montana
Posted: 08/15/07 09:02am Link  |  Print  |  Notify Moderator
Just my .02
I used gorilla glue,
The expensive tight grain fir #1 or #2 wood
Stainless steel hardware.
I think using the spray in foam "great stuff" and giving it an "out" will add structure to your corners (just a bit of shear) trim the foam and add the outside sheets.
For corner jacks, I would think using a plate,not just large washers, inside could solve some structure issues if water becomes an issue again?
Repo
Edit: Great opertunity to buy a staple air gun, and spend the extra on the good staples,I had to order the good ones.
05 Tundra 4x4
1977' Road Ranger, Diddums is in action.
KMLsquared
Cotati CA
Posted: 08/15/07 10:00am Link  |  Print  |  Notify Moderator
LOL I think i can barrow one.
Would that tight grain fir be at like a home depot or lowes?
John H
Kansas City Mo.
Posted: 08/15/07 01:49pm Link  |  Print  |  Notify Moderator
KML,
Go back to "Big Job Rot Repair" on 8/01/07, there I gave him (you) my description on my Jayco rot job.
John H
hilandfrog
Montana
Posted: 08/15/07 02:46pm Link  |  Print  |  Notify Moderator
Listen to that Jonh H guy......[emoticon]
If I remember correctly a standard 1" x 2" x 8' is under $2.50.
The good stuff, for my HD is over by the trim and moulding, costs $4-5.
Huge diff in the quality once you have the good stuff in your hands.
Repo
